Introduzione
Replacing this fuse lets the kettle heat water again.
  1. This is an Oster Digital Electric Kettle This is an Oster Digital Electric Kettle
    • This is an Oster Digital Electric Kettle
  2. Remove the three screws. They are tri-wing  or triangular slotted screws. My set labeled them as number 4. Once removed the plastic cover comes right off. Once removed the plastic cover comes right off.
    • Remove the three screws. They are tri-wing or triangular slotted screws. My set labeled them as number 4.
    • Once removed the plastic cover comes right off.
  3. The Thermal Cutoff Fuse is pressed up against the heat element by a spring clip. Remove the screw, a standard number 2 phillips head. Slide the fiberglass sleeve down and off the fuse
    • The Thermal Cutoff Fuse is pressed up against the heat element by a spring clip.
    • Remove the screw, a standard number 2 phillips head.
    • Slide the fiberglass sleeve down and off the fuse
  4. Kit di riparazione per Android
    Un nuovo schermo o una nuova batteria sono ad un kit di distanza.
    Acquista ora
    Acquista ora
  5. With ohm meter connected either way the fuse is open. A sure sign that the part is bad. With ohm meter connected either way the fuse is open. A sure sign that the part is bad.
    • With ohm meter connected either way the fuse is open. A sure sign that the part is bad.
  6. Testing the new fuse shows that electricity can flow through it. I purchased 5x of SF188E 192 10A/250V SEFUSE on ebay. You can just search for whatever is written on the side of yours.
    • Testing the new fuse shows that electricity can flow through it.
    • I purchased 5x of SF188E 192 10A/250V SEFUSE on ebay. You can just search for whatever is written on the side of yours.
  7. Replace the fuse. The black band is down in this picture. The difficult part is that this part is not soldered in, it is held together with a crimp band.
    • Replace the fuse. The black band is down in this picture.
    • The difficult part is that this part is not soldered in, it is held together with a crimp band.
    • So one must slowly open the band and then crimp it back on the new fuse.
    • I really have no good way of doing this, and it is the most time consuming and frustrating part of the whole repair. Take your time with a pick and pliers and slowly open them and replace the fuse.
  8. Now just slide the fiberglass sleeve back over the fuse. Reattach the spring clip to hold the fuse on the heat element.
    • Now just slide the fiberglass sleeve back over the fuse.
    • Reattach the spring clip to hold the fuse on the heat element.
    • Make sure that the clip is directly over the fuse before tightening.
    • Replace the plastic cover and install the three tri-wing screws.
  9. Plug it back in and see if it heats water.
    • Plug it back in and see if it heats water.
Conclusione
Altre 19 persone hanno completato questa guida.
Scot Henderson
Membro da: 18/05/2015
696 Reputation
2 Guide realizzate
Мне нравится этот чайник мне его подарили но проблема у нас электричество на 220 вольт. Вопрос как эго переделать на 220.
digital electronic kettle
Model: BVST-EK5967
120Vac 60HZ
vikangel - Replica
я не думаю, что это будет иметь значение для предохранителя. плавкий предохранитель рассчитан на 250 в, так что это может быть тот же предохранитель в 220 чайника.
я хотел бы посмотреть на предохранитель и посмотреть, если вы можете прочитать его. тогда просто заменить с тем же.
Scot Henderson - Replica
Where is fuse in Oster electric kettle BVSTKT5970
munu88 - Replica
this helped me 100 percent
joshua hofer - Replica
These steps worked fine for me. They are clear and concise. On Step 6, rather than trying to pry the crimp bands off, I cut them off and used new bands that came with the new fuse - much quicker.
Philip McCue - Replica
Past 24 Hours: 3
Past 7 Days: 42
Past 30 Days: 134
All Time: 11,357
