Salta al contenuto principale
Oster Blend-N-Go My Blend Blade Assembly Seal Replacement
Cosa ti serve
  1. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement, Blender Bottle: passo 1, immagine 1 di 2 Oster Blend-N-Go My Blend Blade Assembly Seal Replacement, Blender Bottle: passo 1, immagine 2 di 2
    • Grip the blender base with one hand and blender bottle with the other hand.
    • Rotate the blender bottle a quarter turn counterclockwise .
    • Lift the blender bottle out of the blender base. The blade assembly should still be attached to the blender bottle.
  2. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: passo 2, immagine 1 di 3 Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: passo 2, immagine 2 di 3 Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: passo 2, immagine 3 di 3
    • Grip the blade assembly with one hand and blender bottle with the other hand.
    • Rotate the blade assembly counterclockwise until it is completely unscrewed from the blender bottle.
    • Lift the blender bottle to separate it from the blade assembly.
  3. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement, Blade Assembly: passo 3, immagine 1 di 1
    • After removing the blade assembly from the blender bottle, ensure your blade assembly has its seal placed in the seal bed.
  4. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement, Blade Assembly Seal: passo 4, immagine 1 di 1
    • After separating the blade assembly from the blender bottle, position the plastic opening tool on either side of the seal in the blade assembly.
    • Wedge tool between seal and seal seat wall.
  5. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: passo 5, immagine 1 di 1
    • Gently pry the seal up while lifting seal out of the seal seat.
  6. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: passo 6, immagine 1 di 2 Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: passo 6, immagine 2 di 2
    • Place and press the new seal into seal seat with finger.
Conclusione
Altre 3 persone hanno completato questa guida.
Paul Long
Membro da: 08/27/15
710 Reputazione
4 Guide realizzate
USF Tampa, Team 12-6, Blackwell Fall 2015 Membro di USF Tampa, Team 12-6, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G6
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,933
