Salta al contenuto principale
Oster Blend-N-Go My Blend Blade Assembly Replacement
  1. Oster Blend-N-Go My Blend Blade Assembly Replacement, Blender Bottle: passo 1, immagine 1 di 2 Oster Blend-N-Go My Blend Blade Assembly Replacement, Blender Bottle: passo 1, immagine 2 di 2
    • Grip the blender base with one hand and blender bottle with the other hand.
    • Rotate the blender bottle a quarter turn counterclockwise .
    • Lift the blender bottle out of the blender base. The blade assembly should still be attached to the blender bottle.
  2. Oster Blend-N-Go My Blend Blade Assembly Replacement: passo 2, immagine 1 di 3 Oster Blend-N-Go My Blend Blade Assembly Replacement: passo 2, immagine 2 di 3 Oster Blend-N-Go My Blend Blade Assembly Replacement: passo 2, immagine 3 di 3
    • Grip the blade assembly with one hand and blender bottle with the other hand.
    • Rotate the blade assembly counterclockwise until it is completely unscrewed from the blender bottle.
    • Lift the blender bottle to separate it from the blade assembly.
  3. Oster Blend-N-Go My Blend Blade Assembly Replacement, Blade Assembly: passo 3, immagine 1 di 1
    • After removing the blade assembly from the blender bottle, ensure your blade assembly has its seal placed in the seal bed.
Conclusione
Paul Long
Membro da: 08/27/15
710 Reputazione
4 Guide realizzate
USF Tampa, Team 12-6, Blackwell Fall 2015 Membro di USF Tampa, Team 12-6, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G6
3 Membri
5 Guide realizzate
2 Commenti
I’m confused, these are the steps you have to go through every single time you use this blender to blend something. This isn’t really a “replacement” process here. If someone needs to repair a cracked blade assembly or buy a new one, how would they do that?
Alan M - Replica
This process is not helpful at all. I followed as instructed but the blade is not moving at all?! What is going on? Pls provide better HELP INSTRUCTIONS.
Fareda Edwards - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 23
Tutti i Tempi: 3,626
