Salta al contenuto principale
Oster BLSTSS-PZO Blades & Seal Ring Replacement
  1. Oster BLSTSS-PZO Blades & Seal Ring Replacement, Blades & Seal Ring: passo 1, immagine 1 di 1
    • First, remove the blender container from the blender base by grabbing the container and lifting it up.
  2. Oster BLSTSS-PZO Blades & Seal Ring Replacement: passo 2, immagine 1 di 1
    • Flip the container, where the bottom faces you.
    • Then, rotate the bottom piece counter-clockwise to remove it from the container.
  3. Oster BLSTSS-PZO Blades & Seal Ring Replacement: passo 3, immagine 1 di 1
    • Carefully remove the bottom piece from the container.
    • Be careful while removing the blades from the container, as seeing they are very sharp and can hurt you.
  4. Oster BLSTSS-PZO Blades & Seal Ring Replacement: passo 4, immagine 1 di 1
    • Now, your container and blades are separated.
Conclusione
Farhan
Membro da: 09/20/17
104 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 462
