Salta al contenuto principale
Oster 3905 Retractable Cord Replacement
Cosa ti serve
  1. Oster 3905 Retractable Cord Replacement, Slot Levers: passo 1, immagine 1 di 1
    • Firmly grip your hand around the slot lever.
  2. Oster 3905 Retractable Cord Replacement: passo 2, immagine 1 di 1
    • Stabilize the toaster by placing your hand on top.
  3. Oster 3905 Retractable Cord Replacement: passo 3, immagine 1 di 2 Oster 3905 Retractable Cord Replacement: passo 3, immagine 2 di 2
    • Forcefully pull the slot lever away from the toaster by keeping parallel to the table.
  4. Oster 3905 Retractable Cord Replacement: passo 4, immagine 1 di 1
    • Both slot levers can be removed.
  5. Oster 3905 Retractable Cord Replacement, Outer Shell: passo 5, immagine 1 di 1
    • Place the toaster upside down so the bottom is facing the ceiling.
  6. Oster 3905 Retractable Cord Replacement: passo 6, immagine 1 di 2 Oster 3905 Retractable Cord Replacement: passo 6, immagine 2 di 2
    • Take off both rubber feet using a small metal spudger.
    • Wedge a spudger under the feet and pull up to pop off.
  7. Oster 3905 Retractable Cord Replacement: passo 7, immagine 1 di 1
    • Use a PH#2 screw bit to remove eight 12mm screws that are located around the perimeter.
    • There are two screws under the rubber feet.
  8. Oster 3905 Retractable Cord Replacement: passo 8, immagine 1 di 1
    • Place the toaster right side up.
  9. Oster 3905 Retractable Cord Replacement: passo 9, immagine 1 di 2 Oster 3905 Retractable Cord Replacement: passo 9, immagine 2 di 2
    • Grab the outer shell firmly and pull up towards the face of the toaster.
  10. Oster 3905 Retractable Cord Replacement: passo 10, immagine 1 di 1
    • For this part, you might need to wiggle the toaster to get the outer shell off.
    • The shell will not completely come off until the motherboard is removed in the next step.
  11. Oster 3905 Retractable Cord Replacement: passo 11, immagine 1 di 3 Oster 3905 Retractable Cord Replacement: passo 11, immagine 2 di 3 Oster 3905 Retractable Cord Replacement: passo 11, immagine 3 di 3
    • Use a J1 screw bit to unscrew eight 8mm screws from the motherboard.
  12. Oster 3905 Retractable Cord Replacement: passo 12, immagine 1 di 2 Oster 3905 Retractable Cord Replacement: passo 12, immagine 2 di 2
    • Take out the grey “cancel” and “bagel” buttons from the shell.
  13. Oster 3905 Retractable Cord Replacement, Retractable Cord: passo 13, immagine 1 di 1
    • Rotate the toaster so that the back is facing towards you.
  14. Oster 3905 Retractable Cord Replacement: passo 14, immagine 1 di 2 Oster 3905 Retractable Cord Replacement: passo 14, immagine 2 di 2
    • Use the PH#1 bit to remove one 8mm screw located above the wire on the casing.
    • Then use the same screw bit to remove two 10mm screws found at the bottom.
  15. Oster 3905 Retractable Cord Replacement: passo 15, immagine 1 di 2 Oster 3905 Retractable Cord Replacement: passo 15, immagine 2 di 2
    • Using the metal spudger, pry next to the black clip found at the base of the toaster and the casing.
    • Push down to separate the casing from the toaster.
  16. Oster 3905 Retractable Cord Replacement: passo 16, immagine 1 di 2 Oster 3905 Retractable Cord Replacement: passo 16, immagine 2 di 2
    • Gently tilt the casing towards the toaster as you pull up from the base.
  17. Oster 3905 Retractable Cord Replacement: passo 17, immagine 1 di 1
    • Use the PH#1 bit to remove the three 8mm screws located on the back side of the casing.
  18. Oster 3905 Retractable Cord Replacement: passo 18, immagine 1 di 2 Oster 3905 Retractable Cord Replacement: passo 18, immagine 2 di 2
    • When opening the casing a metal spring may suddenly pop out.
    • Use the metal spudger to pry open the two halves of the casing.
    • If you are having some trouble only using the metal spudger do not be afraid of using your fingers to pry the casing apart.
  19. Oster 3905 Retractable Cord Replacement: passo 19, immagine 1 di 3 Oster 3905 Retractable Cord Replacement: passo 19, immagine 2 di 3 Oster 3905 Retractable Cord Replacement: passo 19, immagine 3 di 3
    • Carefully remove the spool keeping your fingers on either side of the casing.
    • Tape down the metal spring to keep it from unraveling out of place.
  20. Oster 3905 Retractable Cord Replacement: passo 20, immagine 1 di 3 Oster 3905 Retractable Cord Replacement: passo 20, immagine 2 di 3 Oster 3905 Retractable Cord Replacement: passo 20, immagine 3 di 3
    • Carefully unwind the power cord from the spool.
Conclusione
Adam Dierkes
Membro da: 09/12/16
140 Reputazione
1 Guida realizzata
CSU Fullerton, Team 2-1, Bruce Fall 2016 Membro di CSU Fullerton, Team 2-1, Bruce Fall 2016
CSUF-BRUCE-F16S2G1
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 560
