Salta al contenuto principale
Oster 16-Speed Blender Container Replacement
Cosa ti serve
  1. Oster 16-Speed Blender Container Replacement, Container: passo 1, immagine 1 di 2 Oster 16-Speed Blender Container Replacement, Container: passo 1, immagine 2 di 2
    • First, remove the blender container from the Blender Base, by grabbing the handle and lifting up.
  2. Oster 16-Speed Blender Container Replacement: passo 2, immagine 1 di 2 Oster 16-Speed Blender Container Replacement: passo 2, immagine 2 di 2
    • Next, remove the lid from the Blender Container.
  3. Oster 16-Speed Blender Container Replacement: passo 3, immagine 1 di 2 Oster 16-Speed Blender Container Replacement: passo 3, immagine 2 di 2
    • Flip the container on its side so that the bottom faces you.
    • Now rotate the bottom counter-clockwise to remove it from the container.
  4. Oster 16-Speed Blender Container Replacement: passo 4, immagine 1 di 2 Oster 16-Speed Blender Container Replacement: passo 4, immagine 2 di 2
    • Now you will see the bottom of the blender blades once the bottom piece is removed
    • Carefully remove the blender blades from the container seeing as they are very sharp and can cut you.
  5. Oster 16-Speed Blender Container Replacement: passo 5, immagine 1 di 1
    • Now your container is separated.
Conclusione
With your container separated, it can now be replaced. To reassemble your device, follow these instructions in reverse order.
Dana
Membro da: 04/14/14
773 Reputazione
5 Guide realizzate
Cal Poly, Team 12-37, Maness Spring 2014 Membro di Cal Poly, Team 12-37, Maness Spring 2014
CPSU-MANESS-S14S12G37
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,010
