Introduzione
The trigger button is the one of the most used buttons on the DJI Osmo Mobile, and this guide will serve to teach the device owner how to replace a broken or unresponsive trigger button.
Cosa ti serve
Remove gimbal from base handle by loosening round plate found at the top of the handle.
Locate four screws directly on top of handle.
Unscrew the silver, bottom two screws, that are closest to the face plate using the 00 screwdriver.
Unscrew the black, top two screws, located furthest from the face plate, using the 0 screwdriver.
Remove the remaining two screws found on the front of the faceplate.
Remove the rest of the face plate shell.
Remove the top left screw on the joystick panel with Phillips #00 screwdriver.
Lift faceplate holding joystick module.
