Introduzione
Learn how to take apart the Osmo Mobile handle in order to gain access to other repairs such as the joystick, Bluetooth apparatus, trigger buttons and the charging port.
Cosa ti serve
Remove gimbal from base handle by loosening round plate found at the top of the handle.
Locate four screws directly on top of handle.
Unscrew the silver, bottom two screws, that are closest to the face plate using the 00 screwdriver.
Unscrew the black, top two screws, located furthest from the face plate, using the 0 screwdriver.
Remove the remaining two screws found on the front of the faceplate.
Remove the rest of the face plate shell.
Altre 3 persone hanno completato questa guida.
10 Commenti
I would not call that a handle disassembly. This instruction takes you up to the things you need to do PRIOR to disassembly.
I can show you the rest in a video format if you’re interested
Could you please show me how to fix the USB port that wenr inside the handle? on my Smove gimbal stabilizer
My osmo has snapped off at the metal camera attachment. Can this be repaired ?
Your help would be greatly appreciated
