Salta al contenuto principale
Oscilloscope Probe SMD Resistor Replacement
Cosa ti serve
  1. Oscilloscope Probe SMD Resistor Replacement, SMD Resistor: passo 1, immagine 1 di 3 Oscilloscope Probe SMD Resistor Replacement, SMD Resistor: passo 1, immagine 2 di 3 Oscilloscope Probe SMD Resistor Replacement, SMD Resistor: passo 1, immagine 3 di 3
    • Insert a spudger between the rubber portion of the cable and the plastic casing.
    • Slowly work the spudger around the cable while twisting in order to pry the rubber away from the plastic casing.
    • Be careful not to let the spudger slip.
    • Once the rubber is separated from the plastic casing, slide the plastic casing away from the head of the cable.
    Chiedi a FixBot
    Aggiungi Commento
  2. Oscilloscope Probe SMD Resistor Replacement: passo 2, immagine 1 di 2 Oscilloscope Probe SMD Resistor Replacement: passo 2, immagine 2 di 2
    • Plug the BNC probe into a oscilloscope and connect the probe leads to the test connections located under the screen.
    • Press the autoscale button while holding the connections in place.
    • If you do not see a square wave as in image two, the probe is broken and you should continue to the rest of the guide. If you do see a square wave there is a different issue.
    Chiedi a FixBot
    Aggiungi Commento
  3. Oscilloscope Probe SMD Resistor Replacement: passo 3, immagine 1 di 3 Oscilloscope Probe SMD Resistor Replacement: passo 3, immagine 2 di 3 Oscilloscope Probe SMD Resistor Replacement: passo 3, immagine 3 di 3
    • Use the digital multimeter to measure the resistance across the resistor.
    • If the display reads Overload, select an 0805 size resistor with a matching value, and proceed to step 4. Otherwise, you may have a different issue with your cable.
    Chiedi a FixBot
    Aggiungi Commento
  4. Oscilloscope Probe SMD Resistor Replacement: passo 4, immagine 1 di 3 Oscilloscope Probe SMD Resistor Replacement: passo 4, immagine 2 di 3 Oscilloscope Probe SMD Resistor Replacement: passo 4, immagine 3 di 3
    • This step involves moving the soldering iron quickly between the pads, increasing the risk of burns.
    • Use a vice to hold the probe in place while soldering.
    • Add solder to both sides of the resistor.
    • Heat up the solder on one side of the resistor. Once you see the solder start to melt, immediately start heating up the solder on the other side of the resistor until you see the solder starting to melt. Repeat until the resistor is removed.
    Chiedi a FixBot
    Aggiungi Commento
  5. Oscilloscope Probe SMD Resistor Replacement: passo 5, immagine 1 di 3 Oscilloscope Probe SMD Resistor Replacement: passo 5, immagine 2 di 3 Oscilloscope Probe SMD Resistor Replacement: passo 5, immagine 3 di 3
    • Use tweezers to hold the new resistor in place.
    • Add solder to the tip of your iron.
    • Solder on one side of the resistor. After one side is fixed, you can stop using the tweezers, and then solder on the other side of the resistor.
    • You might accidentally burn the plastic on the probe while soldering on the resistor. Please ensure you have proper ventilation (fume extractor recommended!) to avoid inhaling the plastic fumes.
    Chiedi a FixBot
    Aggiungi Commento
  6. Oscilloscope Probe SMD Resistor Replacement: passo 6, immagine 1 di 2 Oscilloscope Probe SMD Resistor Replacement: passo 6, immagine 2 di 2
    • Use the oscilloscope to test the cable. Follow the same procedure as in step 2.
    • If the repair has worked, you will now see a square wave display on the screen.
    Chiedi a FixBot
    Aggiungi Commento
  7. Oscilloscope Probe SMD Resistor Replacement: passo 7, immagine 1 di 3 Oscilloscope Probe SMD Resistor Replacement: passo 7, immagine 2 di 3 Oscilloscope Probe SMD Resistor Replacement: passo 7, immagine 3 di 3
    • Spray the circuit board with Isopropyl Alcohol to clean it.
    • Gently wipe down the circuit with Kim Wipes. Do not use regular cloth to avoid lint build up on the circuit board.
    Chiedi a FixBot
    Aggiungi Commento
  8. Oscilloscope Probe SMD Resistor Replacement: passo 8, immagine 1 di 3 Oscilloscope Probe SMD Resistor Replacement: passo 8, immagine 2 di 3 Oscilloscope Probe SMD Resistor Replacement: passo 8, immagine 3 di 3
    • Slide the plastic casing back over the circuit board. Ensure that the small hole in the top of the casing lines up with the screw on the capacitor.
    • Slide the rubber neck of the cable back on. Ensure that there is no gap between the rubber neck and the plastic casing.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Congrats on completing this guide! You have helped reduce the toxic waste contribution from discarded lab equipment.
Abhineet Pal
Membro da: 10/09/25
157 Reputazione
Una guida realizzata
UC Davis, Team 1-4, Morris Fall 2025 Membro di UC Davis, Team 1-4, Morris Fall 2025
UCD-MORRIS-F25S1G4
3 Membri
1 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 7
Ultimi 30 giorni: 46
Tutti i Tempi: 331
