Salta al contenuto principale
Origin EON17-S mSATA SSDs Replacement
Cosa ti serve
  1. Origin EON17-S mSATA SSDs Replacement, mSATA SSDs: passo 1, immagine 1 di 1
    • Opening your computer can be dangerous; give it at least 10 minutes to cool down after shutdown and ensure the power supply and battery are disconnected.
    • Disconnect all peripherals.
    • Disconnect the power cord.
    • Lay the computer upside-down.
  2. Origin EON17-S mSATA SSDs Replacement: passo 2, immagine 1 di 2 Origin EON17-S mSATA SSDs Replacement: passo 2, immagine 2 di 2
    • Push both locking tabs inward. One is spring loaded and will need to be held while removing the battery.
    • Remove the battery by pulling up on the tab.
    • To replace the drive in mSATA bay 1, continue to Step 3.
    • To replace the drive in mSATA bay 2, proceed to Step 7.
    • If you are unsure which drive you are replacing, follow all of the remaining steps.
  3. Origin EON17-S mSATA SSDs Replacement: passo 3, immagine 1 di 3 Origin EON17-S mSATA SSDs Replacement: passo 3, immagine 2 di 3 Origin EON17-S mSATA SSDs Replacement: passo 3, immagine 3 di 3
    • Performing the following actions incorrectly can damage your hard drive and could result in lost data. Consider backing up your hard drive(s) before proceeding.
    • Remove the component cover by removing the six screws with a 3/32" screwdriver.
    • Remove the screws from the bottom of the computer.
    • Remove the screws from the back of the computer.
  4. Origin EON17-S mSATA SSDs Replacement: passo 4, immagine 1 di 1
    • Remove the cover by gently pulling back and up.
  5. Origin EON17-S mSATA SSDs Replacement: passo 5, immagine 1 di 1
    • An electrostatic discharge could damage your computer. Use an electrostatic wrist strap when working inside the computer.
    • Put on the electrostatic wrist strap and attach the alligator clip to a sturdy piece of metal inside the case.
  6. Origin EON17-S mSATA SSDs Replacement: passo 6, immagine 1 di 2 Origin EON17-S mSATA SSDs Replacement: passo 6, immagine 2 di 2
    • You will see the mSATA drive in the lower right hand corner of the component area.
    • Remove the screw on the far right side of the drive.
    • The drive will rise up to an angle.
    • Remove the drive by pulling in the direction the drive is positioned.
  7. Origin EON17-S mSATA SSDs Replacement: passo 7, immagine 1 di 2 Origin EON17-S mSATA SSDs Replacement: passo 7, immagine 2 di 2
    • Unscrew the two screws holding the hard drive cover to reveal the second mSATA bay.
    • There are two snaps on this cover, pull firmly but carefully to remove it without breaking them.
  8. Origin EON17-S mSATA SSDs Replacement: passo 8, immagine 1 di 2 Origin EON17-S mSATA SSDs Replacement: passo 8, immagine 2 di 2
    • Removing the hard drive is necessary to get to the second mSATA bay.
    • Remove the hard drive by sliding it towards you.
    • Once it is free of the port, use a screwdriver to gently pry it from the bay.
  9. Origin EON17-S mSATA SSDs Replacement: passo 9, immagine 1 di 1
    • Remove the small, silver, rectangular plate below the hard drive bay.
    • Remove the small screw at the front of the plate.
    • Pull the plate up and out.
  10. Origin EON17-S mSATA SSDs Replacement: passo 10, immagine 1 di 2 Origin EON17-S mSATA SSDs Replacement: passo 10, immagine 2 di 2
    • Remove the small screw on the upper left of the hard drive.
    • The drive will rise up at an angle.
    • Remove the drive by pulling in the direction the drive is currently positioned.
Conclusione
To reassemble your device, do anything you did in reverse.
Caelan Langdon
Membro da: 09/29/15
125 Reputazione
1 Guida realizzata
Cal Poly, Team 15-2, Green Fall 2015 Membro di Cal Poly, Team 15-2, Green Fall 2015
CPSU-GREEN-F15S15G2
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 28
Tutti i Tempi: 3,770
