Salta al contenuto principale
Oregon Scientific RM318PA Power Switch Replacement
Cosa ti serve
  1. Oregon Scientific RM318PA Power Switch Replacement, Battery Compartment Cover: passo 1, immagine 1 di 3 Oregon Scientific RM318PA Power Switch Replacement, Battery Compartment Cover: passo 1, immagine 2 di 3 Oregon Scientific RM318PA Power Switch Replacement, Battery Compartment Cover: passo 1, immagine 3 di 3
    • Hold clock so that the clock face is facing away from you.
    • Using your thumbs, push up on the battery cover.
    • Once battery cover is removed, pull down on AC Adapter Jack.
  2. Oregon Scientific RM318PA Power Switch Replacement, Batteries: passo 2, immagine 1 di 1
    • Use one hand to stabilize the clock.
    • Using your other hand, push batteries toward spring and pull out at an angle.
  3. Oregon Scientific RM318PA Power Switch Replacement, Back of Projection Clock: passo 3, immagine 1 di 3 Oregon Scientific RM318PA Power Switch Replacement, Back of Projection Clock: passo 3, immagine 2 di 3 Oregon Scientific RM318PA Power Switch Replacement, Back of Projection Clock: passo 3, immagine 3 di 3
    • Use a Plastic Opening Tool to pry off the silver casing on the back.
    • Pry at the top of device.
    • Once the back is open at the top, pry at the side of the device closest to the battery compartment.
    • On/Off switch should come off with casing.
  4. Oregon Scientific RM318PA Power Switch Replacement, On/Off Switch: passo 4, immagine 1 di 2 Oregon Scientific RM318PA Power Switch Replacement, On/Off Switch: passo 4, immagine 2 di 2
    • Insert switch into slot as shown in picture. Push in until you hear a "click."
    • Replace the back of the clock by pressing cover back into place.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 23
Tutti i Tempi: 1,398
