Salta al contenuto principale
Oregon Scientific Meep! X2 Screen Replacement
Cosa ti serve
  1. Oregon Scientific Meep! X2 Screen Replacement, Rear Casing: passo 1, immagine 1 di 1
    • Remove the orange covers from the left and right sides of the device by sliding up against the tabs.
  2. Oregon Scientific Meep! X2 Screen Replacement: passo 2, immagine 1 di 3 Oregon Scientific Meep! X2 Screen Replacement: passo 2, immagine 2 di 3 Oregon Scientific Meep! X2 Screen Replacement: passo 2, immagine 3 di 3
    • You can remove the rear casing by unscrewing all six phillips #00(3.5mm x 4.5mm)screws from the left and right side of the device.
  3. Oregon Scientific Meep! X2 Screen Replacement: passo 3, immagine 1 di 3 Oregon Scientific Meep! X2 Screen Replacement: passo 3, immagine 2 di 3 Oregon Scientific Meep! X2 Screen Replacement: passo 3, immagine 3 di 3
    • Use the plastic opening tools to undo the clips around the edges of the device.
  4. Oregon Scientific Meep! X2 Screen Replacement, Power Button: passo 4, immagine 1 di 2 Oregon Scientific Meep! X2 Screen Replacement, Power Button: passo 4, immagine 2 di 2
    • Use a tweezer to gently pull the power button sensor out of the case's slot.
  5. Oregon Scientific Meep! X2 Screen Replacement: passo 5, immagine 1 di 2 Oregon Scientific Meep! X2 Screen Replacement: passo 5, immagine 2 di 2
    • Use the soldering station to unsolder and remove the power button from the motherboard.
    • In the case of screen or screen sensor replacement, disregard desoldering steps.
  6. Oregon Scientific Meep! X2 Screen Replacement, Microphone: passo 6, immagine 1 di 2 Oregon Scientific Meep! X2 Screen Replacement, Microphone: passo 6, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use your tweezers to gently remove the microphone from the slot in the casing.
  7. Oregon Scientific Meep! X2 Screen Replacement: passo 7, immagine 1 di 2 Oregon Scientific Meep! X2 Screen Replacement: passo 7, immagine 2 di 2
    • Unsolder the microphone unit from the motherboard using the soldering station.
  8. Oregon Scientific Meep! X2 Screen Replacement, Cameras: passo 8, immagine 1 di 2 Oregon Scientific Meep! X2 Screen Replacement, Cameras: passo 8, immagine 2 di 2
    • Slip the plastic opening tool under the white, square enclosure of the camera and lift upward to unhook the camera unit from the motherboard.
  9. Oregon Scientific Meep! X2 Screen Replacement: passo 9, immagine 1 di 2 Oregon Scientific Meep! X2 Screen Replacement: passo 9, immagine 2 di 2
    • Pry the second camera out of its slot with one of the plastic opening tools.
    • Be sure to undo the black adhesive foam from the metal casing in order to remove the camera properly.
  10. Oregon Scientific Meep! X2 Screen Replacement: passo 10, immagine 1 di 1
    • Release the black security clip on the ribbon cable with your plastic opening tool.
    • Gently disconnect the gold ribbon cable from the motherboard. The two cameras will remain attached to the ribbon cable.
  11. Oregon Scientific Meep! X2 Screen Replacement, Motherboard: passo 11, immagine 1 di 2 Oregon Scientific Meep! X2 Screen Replacement, Motherboard: passo 11, immagine 2 di 2
    • Undo the security clips on the ribbon cable connection by placing the plastic opening tool between the black and white parts of the clip. Pull downard toward the gold ribbon cable.
    • Once the left and right clips are undone, remove the gold ribbon cable from that connection by gently pulling it out.
  12. Oregon Scientific Meep! X2 Screen Replacement: passo 12, immagine 1 di 2 Oregon Scientific Meep! X2 Screen Replacement: passo 12, immagine 2 di 2
    • Remove the two phillips #00 (4.5mm x 3mm)screws located on the motherboard.
  13. Oregon Scientific Meep! X2 Screen Replacement: passo 13, immagine 1 di 2 Oregon Scientific Meep! X2 Screen Replacement: passo 13, immagine 2 di 2
    • Lift the silver, rectangular blocker in order to expose the right phillips screw #00 (4mm x 3.5mm).
    • Unscrew the left and right phillips #00 (4mm x 3.5mm)screws.
    • Once unscrewed, gently lift the motherboard from the rest of the device.
  14. Oregon Scientific Meep! X2 Screen Replacement, Remove the ribbon cable.: passo 14, immagine 1 di 3 Oregon Scientific Meep! X2 Screen Replacement, Remove the ribbon cable.: passo 14, immagine 2 di 3 Oregon Scientific Meep! X2 Screen Replacement, Remove the ribbon cable.: passo 14, immagine 3 di 3
    • Gently unhook the black security clips to loosen the ribbon cable. Use one of the plastic opening tools.
    • Pull lightly on the ribbon cable to remove it.
  15. Oregon Scientific Meep! X2 Screen Replacement, Sever the adhesive glue on the battery.: passo 15, immagine 1 di 2 Oregon Scientific Meep! X2 Screen Replacement, Sever the adhesive glue on the battery.: passo 15, immagine 2 di 2
    • Use your spudger to separate the battery from the adhesive glue strips and plastic film.
  16. Oregon Scientific Meep! X2 Screen Replacement: passo 16, immagine 1 di 2 Oregon Scientific Meep! X2 Screen Replacement: passo 16, immagine 2 di 2
    • Use a soldering station to unsolder the battery wires from the motherboard.
  17. Oregon Scientific Meep! X2 Screen Replacement, Screen: passo 17, immagine 1 di 2 Oregon Scientific Meep! X2 Screen Replacement, Screen: passo 17, immagine 2 di 2
    • Remove the 10 phillips #00(3.5mm x 4mm) screws around the metal framing of the screen.
    • Leave the clear tape on the back of the screen until you are ready to remove it from the white plastic casing.
  18. Oregon Scientific Meep! X2 Screen Replacement: passo 18, immagine 1 di 2 Oregon Scientific Meep! X2 Screen Replacement: passo 18, immagine 2 di 2
    • Slowly remove the metal frame and screen from the white casing by gently pulling up on the ends of the metal frame.
  19. Oregon Scientific Meep! X2 Screen Replacement: passo 19, immagine 1 di 1
    • Remove the plastic tape from the back of the screen.
    • Carefully separate the screen from the metal framing.
Conclusione
USF Tampa, Team 9-1, Blackwell Winter 2015 Membro di USF Tampa, Team 9-1, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G1
3 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,006
