Salta al contenuto principale
Oregon Scientific Meep! X2 Power Button Replacement
Cosa ti serve
  1. Oregon Scientific Meep! X2 Power Button Replacement, Rear Casing: passo 1, immagine 1 di 1
    • Remove the orange covers from the left and right sides of the device by sliding up against the tabs.
  2. Oregon Scientific Meep! X2 Power Button Replacement: passo 2, immagine 1 di 3 Oregon Scientific Meep! X2 Power Button Replacement: passo 2, immagine 2 di 3 Oregon Scientific Meep! X2 Power Button Replacement: passo 2, immagine 3 di 3
    • You can remove the rear casing by unscrewing all six phillips #00(3.5mm x 4.5mm)screws from the left and right side of the device.
  3. Oregon Scientific Meep! X2 Power Button Replacement: passo 3, immagine 1 di 3 Oregon Scientific Meep! X2 Power Button Replacement: passo 3, immagine 2 di 3 Oregon Scientific Meep! X2 Power Button Replacement: passo 3, immagine 3 di 3
    • Use the plastic opening tools to undo the clips around the edges of the device.
  4. Oregon Scientific Meep! X2 Power Button Replacement, Power Button: passo 4, immagine 1 di 2 Oregon Scientific Meep! X2 Power Button Replacement, Power Button: passo 4, immagine 2 di 2
    • Use a tweezer to gently pull the power button sensor out of the case's slot.
  5. Oregon Scientific Meep! X2 Power Button Replacement: passo 5, immagine 1 di 2 Oregon Scientific Meep! X2 Power Button Replacement: passo 5, immagine 2 di 2
    • Use the soldering station to unsolder and remove the power button from the motherboard.
    • In the case of screen or screen sensor replacement, disregard desoldering steps.
Conclusione
USF Tampa, Team 9-1, Blackwell Winter 2015 Membro di USF Tampa, Team 9-1, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G1
3 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 959
