Salta al contenuto principale
Oregon Scientific Meep! X2 Battery Replacement
Cosa ti serve
  1. Oregon Scientific Meep! X2 Battery Replacement, Rear Casing: passo 1, immagine 1 di 1
    • Remove the orange covers from the left and right sides of the device by sliding up against the tabs.
  2. Oregon Scientific Meep! X2 Battery Replacement: passo 2, immagine 1 di 3 Oregon Scientific Meep! X2 Battery Replacement: passo 2, immagine 2 di 3 Oregon Scientific Meep! X2 Battery Replacement: passo 2, immagine 3 di 3
    • You can remove the rear casing by unscrewing all six phillips #00(3.5mm x 4.5mm)screws from the left and right side of the device.
  3. Oregon Scientific Meep! X2 Battery Replacement: passo 3, immagine 1 di 3 Oregon Scientific Meep! X2 Battery Replacement: passo 3, immagine 2 di 3 Oregon Scientific Meep! X2 Battery Replacement: passo 3, immagine 3 di 3
    • Use the plastic opening tools to undo the clips around the edges of the device.
  4. Oregon Scientific Meep! X2 Battery Replacement, Remove the ribbon cable.: passo 4, immagine 1 di 3 Oregon Scientific Meep! X2 Battery Replacement, Remove the ribbon cable.: passo 4, immagine 2 di 3 Oregon Scientific Meep! X2 Battery Replacement, Remove the ribbon cable.: passo 4, immagine 3 di 3
    • Gently unhook the black security clips to loosen the ribbon cable. Use one of the plastic opening tools.
    • Pull lightly on the ribbon cable to remove it.
  5. Oregon Scientific Meep! X2 Battery Replacement, Sever the adhesive glue on the battery.: passo 5, immagine 1 di 2 Oregon Scientific Meep! X2 Battery Replacement, Sever the adhesive glue on the battery.: passo 5, immagine 2 di 2
    • Use your spudger to separate the battery from the adhesive glue strips and plastic film.
  6. Oregon Scientific Meep! X2 Battery Replacement: passo 6, immagine 1 di 2 Oregon Scientific Meep! X2 Battery Replacement: passo 6, immagine 2 di 2
    • Use a soldering station to unsolder the battery wires from the motherboard.
    • In the case of screen or screen sensor replacement, disregard desoldering steps.
Conclusione
USF Tampa, Team 9-1, Blackwell Winter 2015 Membro di USF Tampa, Team 9-1, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G1
3 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,484
