Salta al contenuto principale
Oreck XL Upright Vacuum Belt Replacement
Cosa ti serve
  1. Oreck XL Upright Vacuum Belt Replacement, Belt: passo 1, immagine 1 di 2 Oreck XL Upright Vacuum Belt Replacement, Belt: passo 1, immagine 2 di 2
    • Using a Phillips-head screwdriver, remove the five screws from the bottom cover.
  2. Oreck XL Upright Vacuum Belt Replacement: passo 2, immagine 1 di 2 Oreck XL Upright Vacuum Belt Replacement: passo 2, immagine 2 di 2
    • Lift the bottom cover off of the vacuum.
  3. Oreck XL Upright Vacuum Belt Replacement: passo 3, immagine 1 di 3 Oreck XL Upright Vacuum Belt Replacement: passo 3, immagine 2 di 3 Oreck XL Upright Vacuum Belt Replacement: passo 3, immagine 3 di 3
    • Caution: The area around the roller is a pinch point. Be aware of your fingers at all times so you don't get caught or pinched.
    • Remove the belt from the roller.
    • The roller is connected to the brush at the front of the vacuum.
    • Slowly pull the belt off. If you have difficulty, spin the roller as you remove the belt.
  4. Oreck XL Upright Vacuum Belt Replacement: passo 4, immagine 1 di 1
    • Pull the other side of the belt off of the motor shaft.
    • There is a small opening between the motor shaft and the side of the vacuum. The belt comes out here.
    • Discard the old belt.
  5. Oreck XL Upright Vacuum Belt Replacement: passo 5, immagine 1 di 1
    • Insert the replacement belt around the motor shaft.
  6. Oreck XL Upright Vacuum Belt Replacement: passo 6, immagine 1 di 3 Oreck XL Upright Vacuum Belt Replacement: passo 6, immagine 2 di 3 Oreck XL Upright Vacuum Belt Replacement: passo 6, immagine 3 di 3
    • Carefully stretch the other end of the belt around the roller.
    • Spin the roller a few times to ensure the belt is secured.
  7. Oreck XL Upright Vacuum Belt Replacement: passo 7, immagine 1 di 1
    • Replace the top cover and the five screws.
Linea Traguardo
Laura S
Membro da: 01/13/25
145 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 42
Ultimi 30 Giorni: 148
Tutti i Tempi: 611
