Salta al contenuto principale
Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement
Cosa ti serve
  1. Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement, Beater Bar/Agitator and Belt: passo 1, immagine 1 di 3 Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement, Beater Bar/Agitator and Belt: passo 1, immagine 2 di 3 Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement, Beater Bar/Agitator and Belt: passo 1, immagine 3 di 3
    • Remove five screws with a long neck Phillips #2 screwdriver.
  2. Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: passo 2, immagine 1 di 3 Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: passo 2, immagine 2 di 3 Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: passo 2, immagine 3 di 3
    • Remove the cover by lifting straight up.
    • Be sure to gently remove in case of bending the plastic.
  3. Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: passo 3, immagine 1 di 2 Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: passo 3, immagine 2 di 2
    • Next remove the agitator and belt.
    • Pull the belt out first so it is easier to lift up the agitator.
    • Retrieve the new beater bar and belt.
  4. Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: passo 4, immagine 1 di 3 Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: passo 4, immagine 2 di 3 Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: passo 4, immagine 3 di 3
    • If it is difficult to remove the belt, remove the side panel first.
    • Remove the screw and slide the panel to remove it.
  5. Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: passo 5, immagine 1 di 3 Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: passo 5, immagine 2 di 3 Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: passo 5, immagine 3 di 3
    • Connect the belt to the motor.
    • Attach the other side to the beater bar.
    • Slowly pull the beater bar into the grooves and push it down.
    • To make the process easier be sure to stretch the belt out manually before replacing.
  6. Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: passo 6, immagine 1 di 2 Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: passo 6, immagine 2 di 2
    • Make sure it is secure in both sides.
  7. Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: passo 7, immagine 1 di 2 Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: passo 7, immagine 2 di 2
    • Slide the side panel back on and tighten the screw.
  8. Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: passo 8, immagine 1 di 3 Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: passo 8, immagine 2 di 3 Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: passo 8, immagine 3 di 3
    • Place the bottom back on the vacuum.
    • Screw in all five of the Phillips #2 screws to reassemble your vacuum.
Conclusione
If you follow the correct steps in order the vacuum should be running and cleaning up messes faster than before.
Isaiah Allard
Membro da: 01/21/25
157 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 25
Tutti i Tempi: 167
