Salta al contenuto principale
Ordro HDV-D395 Lens Replacement
Cosa ti serve
  1. Ordro HDV-D395 Lens Replacement, Lens: passo 1, immagine 1 di 2 Ordro HDV-D395 Lens Replacement, Lens: passo 1, immagine 2 di 2
    • Pull the slider labeled open, on the bottom right, to unlock the battery.
  2. Ordro HDV-D395 Lens Replacement: passo 2, immagine 1 di 1
    • Pull battery out of slot.
  3. Ordro HDV-D395 Lens Replacement: passo 3, immagine 1 di 1
    • Remove the three screws (length 7.7 mm) from the bottom of the outer case using a JIS000 screwdriver.
  4. Ordro HDV-D395 Lens Replacement: passo 4, immagine 1 di 2 Ordro HDV-D395 Lens Replacement: passo 4, immagine 2 di 2
    • Remove plastic casing hiding screws from the strap side of the casing.
    • Unscrew the three screws (length 4.75 mm) using a PH000 screwdriver.
    • Unscrew the two screws (length 6.4 mm) using a JIS000 screwdriver.
  5. Ordro HDV-D395 Lens Replacement: passo 5, immagine 1 di 1
    • Unscrew the four screws (2.9 mm length) from the screen side of the casing using a JIS000 screwdriver.
  6. Ordro HDV-D395 Lens Replacement: passo 6, immagine 1 di 1
    • Remove both side casings by gripping the sides with your hands and pulling gently.
  7. Ordro HDV-D395 Lens Replacement: passo 7, immagine 1 di 3 Ordro HDV-D395 Lens Replacement: passo 7, immagine 2 di 3 Ordro HDV-D395 Lens Replacement: passo 7, immagine 3 di 3
    • Although it requires extra steps, it is advised that you remove the motherboard and screen to ensure that nothing is damaged in the process of replacing the lens.
    • Unscrew the seven screws (length 4.22 mm) from the motherboard using a PH000 screwdriver.
    • Pull out or desolder all connected cords from motherboard.
  8. Ordro HDV-D395 Lens Replacement: passo 8, immagine 1 di 2 Ordro HDV-D395 Lens Replacement: passo 8, immagine 2 di 2
    • Remove top of the casing to reveal the screws on lens.
    • Unscrew the four screws (size 4.90 mm) using a PH00 screwdriver.
  9. Ordro HDV-D395 Lens Replacement: passo 9, immagine 1 di 3 Ordro HDV-D395 Lens Replacement: passo 9, immagine 2 di 3 Ordro HDV-D395 Lens Replacement: passo 9, immagine 3 di 3
    • Pull out lens.
    • Remove cord from lens.
Conclusione
IUPUI, Team S1-G3, Baechle Fall 2018 Membro di IUPUI, Team S1-G3, Baechle Fall 2018
IUPUI-BAECHLE-F18S1G3
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 231
