Salta al contenuto principale
Orbic Wonder Screen Replacement
Cosa ti serve
  1. Orbic Wonder Screen Replacement, Battery: passo 1, immagine 1 di 3 Orbic Wonder Screen Replacement, Battery: passo 1, immagine 2 di 3 Orbic Wonder Screen Replacement, Battery: passo 1, immagine 3 di 3
    • Remove two 2mm TR9 Torx screws from the bottoms of the device.
    Chiedi a FixBot
  2. Orbic Wonder Screen Replacement: passo 2, immagine 1 di 3 Orbic Wonder Screen Replacement: passo 2, immagine 2 di 3 Orbic Wonder Screen Replacement: passo 2, immagine 3 di 3
    • There is a border between the black phone backing and the silver screen.
    • Place the Jimmy in this border, and cautiously torque it back and forth to part the two halves.
    • When the halves are parted correctly, the gap should look like this.
    • Be careful to avoid damaging any connecting circuitry between the two halves.
    Chiedi a FixBot
  3. Orbic Wonder Screen Replacement: passo 3, immagine 1 di 3 Orbic Wonder Screen Replacement: passo 3, immagine 2 di 3 Orbic Wonder Screen Replacement: passo 3, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    • Before continuing, tighten the anti-static wrist strap around your wrist and connect the alligator clips to a metal portion of the phone.
    • On the upper right side, there is a black ribbon cable in the shape of an “L”. Remove the single 1 mm Phillips #000 screw on the left side of the ribbon cable.
    Chiedi a FixBot
  4. Orbic Wonder Screen Replacement: passo 4, immagine 1 di 3 Orbic Wonder Screen Replacement: passo 4, immagine 2 di 3 Orbic Wonder Screen Replacement: passo 4, immagine 3 di 3
    $3.99
    • Use a pair of angled tweezers to carefully remove the metal casing of the ribbon cable.
    • Use a pair of angled tweezers to detach the black ribbon cable. This is done to unplug the battery.
    Chiedi a FixBot
  5. Orbic Wonder Screen Replacement: passo 5, immagine 1 di 3 Orbic Wonder Screen Replacement: passo 5, immagine 2 di 3 Orbic Wonder Screen Replacement: passo 5, immagine 3 di 3
    • There is a black flap on the bottom of the battery.
    • Using your fingers, pinch this flap and carefully pull the battery up and out of the phone.
    Chiedi a FixBot
  6. Orbic Wonder Screen Replacement, Speaker: passo 6, immagine 1 di 3 Orbic Wonder Screen Replacement, Speaker: passo 6, immagine 2 di 3 Orbic Wonder Screen Replacement, Speaker: passo 6, immagine 3 di 3
    $7.95
    • Remove the anti-static wrist strap.
    • Use the Phillips #000 screwdriver to remove the five black 2 mm screws.
    • Use the Phillips #000 screwdriver to remove the two grey 2 mm screws.
    Chiedi a FixBot
  7. Orbic Wonder Screen Replacement: passo 7, immagine 1 di 2 Orbic Wonder Screen Replacement: passo 7, immagine 2 di 2
    $3.99
    Chiedi a FixBot
  8. Orbic Wonder Screen Replacement, Charging Port Circuit Board: passo 8, immagine 1 di 3 Orbic Wonder Screen Replacement, Charging Port Circuit Board: passo 8, immagine 2 di 3 Orbic Wonder Screen Replacement, Charging Port Circuit Board: passo 8, immagine 3 di 3
    $3.99
    • Detach the metal casing at the bottom of the phone.
    • Unplug the cable connector.
    • Use a pair of angled tweezers to unplug the black wire.
    Chiedi a FixBot
  9. Orbic Wonder Screen Replacement: passo 9, immagine 1 di 3 Orbic Wonder Screen Replacement: passo 9, immagine 2 di 3 Orbic Wonder Screen Replacement: passo 9, immagine 3 di 3
    • Using a pair of angled tweezers, disconnect the connector chip.
    • With the angled tweezers, gently lift (but do not remove) the green circuit board from the phone.
    Chiedi a FixBot
  10. Orbic Wonder Screen Replacement: passo 10, immagine 1 di 2 Orbic Wonder Screen Replacement: passo 10, immagine 2 di 2
    • Using a pair of angled tweezers, disconnect the attachment to the microphone labeled "JD," and completely remove the circuit board.
    Chiedi a FixBot
  11. Orbic Wonder Screen Replacement, Screen: passo 11, immagine 1 di 2 Orbic Wonder Screen Replacement, Screen: passo 11, immagine 2 di 2
    • Remove the six 2mm Phillips #000 screws from the motherboard.
    Chiedi a FixBot
  12. Orbic Wonder Screen Replacement: passo 12, immagine 1 di 2 Orbic Wonder Screen Replacement: passo 12, immagine 2 di 2
    • Use a pair of tweezers to remove the leftmost metal protector.
    • Repeat this process for the other metal protector directly above the battery.
    Chiedi a FixBot
  13. Orbic Wonder Screen Replacement: passo 13, immagine 1 di 3 Orbic Wonder Screen Replacement: passo 13, immagine 2 di 3 Orbic Wonder Screen Replacement: passo 13, immagine 3 di 3
    • Disconnect the "L" shaped plug connecting the battery to the circuit board.
    • Carefully disconnect the small gold connecting wire.
    • Disconnect the rectangular piece.
    • Each of these steps are very delicate. Use a pair of tweezers to avoid causing damage.
    Chiedi a FixBot
  14. Orbic Wonder Screen Replacement: passo 14, immagine 1 di 2 Orbic Wonder Screen Replacement: passo 14, immagine 2 di 2
    • Unplug the power button connector.
    • Unplug the circuit connector above the battery.
    • These are very delicate and important connections. Be sure to use a pair of tweezers to avoid causing damage.
    Chiedi a FixBot
  15. Orbic Wonder Screen Replacement: passo 15, immagine 1 di 2 Orbic Wonder Screen Replacement: passo 15, immagine 2 di 2
    • Carefully remove the protective sticker. This will expose the camera and its connector.
    Chiedi a FixBot
  16. Orbic Wonder Screen Replacement: passo 16, immagine 1 di 2 Orbic Wonder Screen Replacement: passo 16, immagine 2 di 2
    • Disconnect the camera connector.
    Chiedi a FixBot
  17. Orbic Wonder Screen Replacement: passo 17, immagine 1 di 1
    • The circuit board should now be loose. Disconnect it, and remove it from the phone housing.
    Chiedi a FixBot
  18. Orbic Wonder Screen Replacement: passo 18, immagine 1 di 3 Orbic Wonder Screen Replacement: passo 18, immagine 2 di 3 Orbic Wonder Screen Replacement: passo 18, immagine 3 di 3
    • Using the iOpener, heat the screen's edges to loosen the adhesive holding the screen in place.
    • This will make the phone very warm. Gloves may be necessary depending on the level of heat required.
    • Using the Jimmy and opening picks, gently pry the screen from the phone housing.
    Chiedi a FixBot
  19. Orbic Wonder Screen Replacement: passo 19, immagine 1 di 2 Orbic Wonder Screen Replacement: passo 19, immagine 2 di 2
    • Push the gold lower screen connector wire through the hole.
    • Do the same to the gold upper screen connector wire.
    Chiedi a FixBot
  20. Orbic Wonder Screen Replacement: passo 20, immagine 1 di 3 Orbic Wonder Screen Replacement: passo 20, immagine 2 di 3 Orbic Wonder Screen Replacement: passo 20, immagine 3 di 3
    • Using your hands, separate the screen from the rest of the phone, ensuring that the connector wires go through the openings without ripping.
    • The screen is completely detached from the rest of the phone.
    Chiedi a FixBot
Conclusione
3Commenti sulla guida
how can and or can I swap media files from orbic wonder “with damaged screen “ to a gaxalxy a01
Ron Harrell - Rispondi Condividi
My orbic was over amped.7 volts burned something out.it turns on but nothing works.and the screen is light grey.how do i repair this plz thank you. 209crazo
209 Crazo - Rispondi Condividi
I need orbic lcd
Gzn Khan - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 15
Ultimi 30 giorni: 85
Tutti i Tempi: 4,030
