Salta al contenuto principale
Orbic Wonder Charging Port Circuit Board Replacement
Cosa ti serve
  1. Orbic Wonder Charging Port Circuit Board Replacement, Battery: passo 1, immagine 1 di 3 Orbic Wonder Charging Port Circuit Board Replacement, Battery: passo 1, immagine 2 di 3 Orbic Wonder Charging Port Circuit Board Replacement, Battery: passo 1, immagine 3 di 3
    • Remove two 2mm TR9 Torx screws from the bottoms of the device.
    Chiedi a FixBot
  2. Orbic Wonder Charging Port Circuit Board Replacement: passo 2, immagine 1 di 3 Orbic Wonder Charging Port Circuit Board Replacement: passo 2, immagine 2 di 3 Orbic Wonder Charging Port Circuit Board Replacement: passo 2, immagine 3 di 3
    • There is a border between the black phone backing and the silver screen.
    • Place the Jimmy in this border, and cautiously torque it back and forth to part the two halves.
    • When the halves are parted correctly, the gap should look like this.
    • Be careful to avoid damaging any connecting circuitry between the two halves.
    Chiedi a FixBot
  3. Orbic Wonder Charging Port Circuit Board Replacement: passo 3, immagine 1 di 3 Orbic Wonder Charging Port Circuit Board Replacement: passo 3, immagine 2 di 3 Orbic Wonder Charging Port Circuit Board Replacement: passo 3, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    • Before continuing, tighten the anti-static wrist strap around your wrist and connect the alligator clips to a metal portion of the phone.
    • On the upper right side, there is a black ribbon cable in the shape of an “L”. Remove the single 1 mm Phillips #000 screw on the left side of the ribbon cable.
    Chiedi a FixBot
  4. Orbic Wonder Charging Port Circuit Board Replacement: passo 4, immagine 1 di 3 Orbic Wonder Charging Port Circuit Board Replacement: passo 4, immagine 2 di 3 Orbic Wonder Charging Port Circuit Board Replacement: passo 4, immagine 3 di 3
    $3.99
    • Use a pair of angled tweezers to carefully remove the metal casing of the ribbon cable.
    • Use a pair of angled tweezers to detach the black ribbon cable. This is done to unplug the battery.
    Chiedi a FixBot
  5. Orbic Wonder Charging Port Circuit Board Replacement: passo 5, immagine 1 di 3 Orbic Wonder Charging Port Circuit Board Replacement: passo 5, immagine 2 di 3 Orbic Wonder Charging Port Circuit Board Replacement: passo 5, immagine 3 di 3
    • There is a black flap on the bottom of the battery.
    • Using your fingers, pinch this flap and carefully pull the battery up and out of the phone.
    Chiedi a FixBot
  6. Orbic Wonder Charging Port Circuit Board Replacement, Speaker: passo 6, immagine 1 di 3 Orbic Wonder Charging Port Circuit Board Replacement, Speaker: passo 6, immagine 2 di 3 Orbic Wonder Charging Port Circuit Board Replacement, Speaker: passo 6, immagine 3 di 3
    $7.95
    • Remove the anti-static wrist strap.
    • Use the Phillips #000 screwdriver to remove the five black 2 mm screws.
    • Use the Phillips #000 screwdriver to remove the two grey 2 mm screws.
    Chiedi a FixBot
  7. Orbic Wonder Charging Port Circuit Board Replacement: passo 7, immagine 1 di 2 Orbic Wonder Charging Port Circuit Board Replacement: passo 7, immagine 2 di 2
    $3.99
    Chiedi a FixBot
  8. Orbic Wonder Charging Port Circuit Board Replacement, Charging Port Circuit Board: passo 8, immagine 1 di 3 Orbic Wonder Charging Port Circuit Board Replacement, Charging Port Circuit Board: passo 8, immagine 2 di 3 Orbic Wonder Charging Port Circuit Board Replacement, Charging Port Circuit Board: passo 8, immagine 3 di 3
    $3.99
    • Detach the metal casing at the bottom of the phone.
    • Unplug the cable connector.
    • Use a pair of angled tweezers to unplug the black wire.
    Chiedi a FixBot
  9. Orbic Wonder Charging Port Circuit Board Replacement: passo 9, immagine 1 di 3 Orbic Wonder Charging Port Circuit Board Replacement: passo 9, immagine 2 di 3 Orbic Wonder Charging Port Circuit Board Replacement: passo 9, immagine 3 di 3
    • Using a pair of angled tweezers, disconnect the connector chip.
    • With the angled tweezers, gently lift (but do not remove) the green circuit board from the phone.
    Chiedi a FixBot
  10. Orbic Wonder Charging Port Circuit Board Replacement: passo 10, immagine 1 di 2 Orbic Wonder Charging Port Circuit Board Replacement: passo 10, immagine 2 di 2
    • Using a pair of angled tweezers, disconnect the attachment to the microphone labeled "JD," and completely remove the circuit board.
    Chiedi a FixBot
Conclusione
Altre 2 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 11
Ultimi 30 giorni: 70
Tutti i Tempi: 1,837
