Salta al contenuto principale
Oral-B Vitality Power Button Replacement
Cosa ti serve
  1. Oral-B Vitality Power Button Replacement, Power Button: passo 1, immagine 1 di 3 Oral-B Vitality Power Button Replacement, Power Button: passo 1, immagine 2 di 3 Oral-B Vitality Power Button Replacement, Power Button: passo 1, immagine 3 di 3
    • Using the pliers, rotate the head base 90 degrees counterclockwise and remove core from the handle.
  2. Oral-B Vitality Power Button Replacement: passo 2, immagine 1 di 1
    • Locate the 4 terminals connecting the power button to the circuit board.
  3. Oral-B Vitality Power Button Replacement: passo 3, immagine 1 di 3 Oral-B Vitality Power Button Replacement: passo 3, immagine 2 di 3 Oral-B Vitality Power Button Replacement: passo 3, immagine 3 di 3
    • Desolder the 4 terminals and remove the old button.
    • Remove as much of the old solder as possible.
  4. Oral-B Vitality Power Button Replacement: passo 4, immagine 1 di 1
    • Attach the new button by soldering the 4 terminals with new solder.
Conclusione
Altre 8 persone hanno completato questa guida.
IUPUI, Team S2-G1, Harley Fall 2017 Membro di IUPUI, Team S2-G1, Harley Fall 2017
IUPUI-HARLEY-F17S2G1
3 Membri
8 Guide realizzate
4 Commenti
In my case no need to change the button, just redo the solder and this is it.
the vibration has damaged the solder.
Al kri - Replica
If you try to unsolder the battery it has some protection and it won't work anymore
Gigi Kent - Replica
Before unsoldering the button, you can understand if it is good or not just bypassing it with a wire: with a copper wire you can touch two pins of the button (one on the right side, on on the left side); if the toothbrush starts and stop on each touch of the wire, the problem is the button. I recognize the problem in this way.
Manolo Cerello - Replica
True except if the switch is permanently “on”. I think that was my case. Replacing the switch fixed the issue.
Mumble Tim -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 44
Ultimi 30 Giorni: 185
Tutti i Tempi: 9,639
