Introduzione
Use this guide to remove the focal lens from your Optoma HD20.
Cosa ti serve
Twist the focal cap clockwise until it is fully extended.
Remove the focal cap by pulling it straight out.
Remove the ribbon by disconnecting it from the main circuit board.
Lift up the clip holding it down and pull the ribbon out.
The black part is the clip that lifts up. Then gently tug on the cable.
The instructions are out of order here.
Wish I had read your comment before struggling with it for what seemed like hours.
Yes… Advice for when you go into this BEFORE consulting the internet and accidentally RIP it out?
I ripped the ribbon. Where can I find it’s replacement?
Use a Phillips #1 screwdriver to unscrew the small black 2 mm screw on the side of the focal lens.
Remove the focal lens by twisting it clockwise until it comes off.
The pictures don't really do justice to how hard it is to pop the focal cap off. One actually has to pull pretty hard, I was afraid of breaking something, but it all worked out.
eislerzoltan - Replica
you da best <3 ty for comment
Weyland Chiang - Replica
