Salta al contenuto principale
Optoma HD20 Color Wheel Replacement
Cosa ti serve
  1. Optoma HD20 Color Wheel Replacement, Disassembling Optoma HD20 Cover: passo 1, immagine 1 di 2 Optoma HD20 Color Wheel Replacement, Disassembling Optoma HD20 Cover: passo 1, immagine 2 di 2
    • Twist the focal cap clockwise until it is fully extended.
    • Remove the focal cap by pulling it straight out.
    The pictures don't really do justice to how hard it is to pop the focal cap off. One actually has to pull pretty hard, I was afraid of breaking something, but it all worked out.
    eislerzoltan - Replica
    you da best <3 ty for comment
    Weyland Chiang - Replica
  2. Optoma HD20 Color Wheel Replacement: passo 2, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
  3. Optoma HD20 Color Wheel Replacement: passo 3, immagine 1 di 1
    • Use a plastic opening tool to gently pry the top cover off of the device.
    • It is easier to pry off the cover from the back side just above the HDMI ports.
  4. Optoma HD20 Color Wheel Replacement: passo 4, immagine 1 di 1
    • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
    • Remove the ribbon by disconnecting it from the main circuit board.
    • Lift up the clip holding it down and pull the ribbon out.
    The black part is the clip that lifts up. Then gently tug on the cable.
    The instructions are out of order here.
    dlwalter - Replica
    Wish I had read your comment before struggling with it for what seemed like hours.
    eislerzoltan -
    Any advice for if you rip that ribbon?
    robby_g - Replica
    Yes… Advice for when you go into this BEFORE consulting the internet and accidentally RIP it out?
    Mathew Amaral -
    I ripped the ribbon. Where can I find it’s replacement?
    Rohit Ghatol - Replica
  5. Optoma HD20 Color Wheel Replacement, Color Wheel: passo 5, immagine 1 di 1
    • Use the plastic opening tool to remove the wiring.
    Removing the white ribbon wire on mine required pushing out toward the ribbon a gray/brown piece that holds the ribbon in place. Once it is moved out, it slides out easily. No lifting needed, just pushing.
    Human Front Range - Replica
  6. Optoma HD20 Color Wheel Replacement: passo 6, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove the 5.5 mm screws around the pin wheel.
  7. Optoma HD20 Color Wheel Replacement: passo 7, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove 1 more 5.5 mm screw.
  8. Optoma HD20 Color Wheel Replacement: passo 8, immagine 1 di 1
    • Using a flat head screw driver unscrew the back part to release the color wheel.
    • Do this carefully because these screws do not pull out.
  9. Optoma HD20 Color Wheel Replacement: passo 9, immagine 1 di 1
    • Once unscrewed, remove the color wheel, and replace the part.
Conclusione
Altre 6 persone hanno completato questa guida.
Trever
Membro da: 01/22/15
1.264 Reputazione
6 Guide realizzate
Cal Poly, Team 21-23, Maness Winter 2015 Membro di Cal Poly, Team 21-23, Maness Winter 2015
CPSU-MANESS-W15S21G23
4 Membri
6 Guide realizzate
3 Commenti
I've seen 5 guides say that the lens adjustment cover just pulls straight out, but even with significant force, it doesn't budge. Are there two different versions of the HD20 with two different designs for the cover?
srbaucom - Replica
I couldn't get the shroud off until I had the plastic top of the projector mostly off.
dlwalter -
The shroud has clips on it that attach to some bolts coming off the lense so yeah, it will take some force to pop the clips.
dlwalter -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 39
Tutti i Tempi: 8,934
