Salta al contenuto principale
Optoma HD20 Air Filter Replacement
Cosa ti serve
  1. Optoma HD20 Air Filter Replacement, Disassembling Optoma HD20 Cover: passo 1, immagine 1 di 2 Optoma HD20 Air Filter Replacement, Disassembling Optoma HD20 Cover: passo 1, immagine 2 di 2
    • Twist the focal cap clockwise until it is fully extended.
    • Remove the focal cap by pulling it straight out.
    The pictures don't really do justice to how hard it is to pop the focal cap off. One actually has to pull pretty hard, I was afraid of breaking something, but it all worked out.
    eislerzoltan - Replica
    you da best <3 ty for comment
    Weyland Chiang - Replica
  2. Optoma HD20 Air Filter Replacement: passo 2, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
  3. Optoma HD20 Air Filter Replacement: passo 3, immagine 1 di 1
    • Use a plastic opening tool to gently pry the top cover off of the device.
    • It is easier to pry off the cover from the back side just above the HDMI ports.
  4. Optoma HD20 Air Filter Replacement: passo 4, immagine 1 di 1
    • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
    • Remove the ribbon by disconnecting it from the main circuit board.
    • Lift up the clip holding it down and pull the ribbon out.
    The black part is the clip that lifts up. Then gently tug on the cable.
    The instructions are out of order here.
    dlwalter - Replica
    Wish I had read your comment before struggling with it for what seemed like hours.
    eislerzoltan -
    Any advice for if you rip that ribbon?
    robby_g - Replica
    Yes… Advice for when you go into this BEFORE consulting the internet and accidentally RIP it out?
    Mathew Amaral -
    I ripped the ribbon. Where can I find it’s replacement?
    Rohit Ghatol - Replica
  5. Optoma HD20 Air Filter Replacement, Air Filter: passo 5, immagine 1 di 3 Optoma HD20 Air Filter Replacement, Air Filter: passo 5, immagine 2 di 3 Optoma HD20 Air Filter Replacement, Air Filter: passo 5, immagine 3 di 3
    • Carefully peel off each air filter from the device
    • Pull up on the air filter to remove it.
    I did not see at least one filter in my projector after opening it. is it normal?
    anonymous 9202 - Replica
    I didn’t see any either
    Michael - Replica
  6. Optoma HD20 Air Filter Replacement: passo 6, immagine 1 di 1
    • Remove the air filter from the device.
    • Try not to deposit dirt from the air filter into the inside of the device.
    Now that I've opened and found the three dirty filters what do I do with them? Is it to wash, brush, blow or replace? Where do I get new identical filters? Thanks.
    W Assis - Replica
Conclusione
Trever
Membro da: 01/22/15
1.264 Reputazione
6 Guide realizzate
Cal Poly, Team 21-23, Maness Winter 2015 Membro di Cal Poly, Team 21-23, Maness Winter 2015
CPSU-MANESS-W15S21G23
4 Membri
6 Guide realizzate
Un commento
There were no filters where the photos indicate.
Michael - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 54
Tutti i Tempi: 12,038
