Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
This fixes the problem of game discs not being read properly.
  1. Turn over the Gamecube so that the bottom side is facing up. Locate the four screws (circled in red) on each corner of the device. Then, use a 4.5 mm Gamebit screwdriver to remove all four screws. Locate the four screws (circled in red) on each corner of the device. Then, use a 4.5 mm Gamebit screwdriver to remove all four screws.
    • Turn over the Gamecube so that the bottom side is facing up.
    • Locate the four screws (circled in red) on each corner of the device. Then, use a 4.5 mm Gamebit screwdriver to remove all four screws.
  2. With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half. Then place the inside of the unit facing up. With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half. Then place the inside of the unit facing up. With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half. Then place the inside of the unit facing up.
    • With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half. Then place the inside of the unit facing up.
    This can also be done whilst being in the normal upright position after all 4 of the 4.5mm Gamebit screws have been removed. Pull the top of the shell directly upwards and it should slide off easily.
    Less chance of snagging any wires or parts.
    Christopher Cox - Replica
  3. Gently press down on the clips located on either side of the the back panel, as shown, and carefully remove it from the main part of the device.
    • Gently press down on the clips located on either side of the the back panel, as shown, and carefully remove it from the main part of the device.
    A second picture clearly showing which direction to pull the back panel away from the unit would be nice.
    rubixtriangle - Replica
  4. With the back panel removed, carefully unclip the controller ports at the front of the unit.
    • With the back panel removed, carefully unclip the controller ports at the front of the unit.
    • A ribbon cable (outlined in yellow) is still attached to the unit. Do not disconnect this cable.
    • Controller ports are where the controllers plug into the game console, and are a half circular shape.
    well... what happens if accidentally i disconnected it?
    negroporexcelencia - Replica
    presumably nothing major. The CMOS battery is attached to the controller ports, so the most i'd expect is that the gamecube loses it's date/time setting. As long as you reset that before jumping into animal crossing or something, you should be fine. I'm currently doing a teardown of my gamecube, and if something does prove to have gone wrong, i'll report back.
    sigoshi -
    okay, i finished putting it back together. gamecube works fine and surprisingly still remembers what year it is. boots into smash bros and shows memory card contents fine.
    sigoshi -
  5. Use a Phillips screwdriver to remove the two 2 screws(circled in red) that are located on the back of the control port. Carefully separate the gray outer casing of the control port and the circuit board.
    • Use a Phillips screwdriver to remove the two 2 screws(circled in red) that are located on the back of the control port.
    • Carefully separate the gray outer casing of the control port and the circuit board.
    That step is not needed for the laser replacement.
    Vincent Léon - Replica
  6. The left side of the unit contains the cooling fan and its housing. Carefully remove the two (2) screws attaching the cooling fan housing to the unit. Do not detach the red and black cooling fan wire from the main unit.(red wire)
    • The left side of the unit contains the cooling fan and its housing. Carefully remove the two (2) screws attaching the cooling fan housing to the unit.
    • Do not detach the red and black cooling fan wire from the main unit.(red wire)
  7. Remove the four (4) Phillips #1 screws retaining the ground springs (outlined in teal). Carefully remove the ground springs from the main unit as shown in the second photograph.
    • Remove the four (4) Phillips #1 screws retaining the ground springs (outlined in teal).
    • Carefully remove the ground springs from the main unit as shown in the second photograph.
  8. The optical drive is secured to a metal plate. Using a Phillips #2 screwdriver, unscrew the twelve (12) screws that are around the outer edge of the optical drive (circled in red).
    • The optical drive is secured to a metal plate.
    • Using a Phillips #2 screwdriver, unscrew the twelve (12) screws that are around the outer edge of the optical drive (circled in red).
  9. Carefully separate the optical drive assembly from the rest of the GameCube unit. The optical drive assembly is secured to the motherboard underneath by a slot; some force may be required to carefully free the assembly. The metal plate and the actual optical drive will remain attached (picture 3).
    • Carefully separate the optical drive assembly from the rest of the GameCube unit.
    • The optical drive assembly is secured to the motherboard underneath by a slot; some force may be required to carefully free the assembly.
    • The metal plate and the actual optical drive will remain attached (picture 3).
  10. At this point, your optical drive assembly should be separated from your GameCube (picture 1). Flip the optical drive assembly upside down Shown in picture 2, remove the 6 Phillips #1 screws with a philips screwdriver.
    • At this point, your optical drive assembly should be separated from your GameCube (picture 1).
    • Flip the optical drive assembly upside down
    • Shown in picture 2, remove the 6 Phillips #1 screws with a philips screwdriver.
    • Once the screws are removed, gently lift and remove the metal plate (shown in picture 3).
    • Be careful not to disturb the brown ribbon cable (highlighted in the yellow).
  11. Remove the blue wire by gently pulling. Disconnect the Brown cable. This is done by gently pulling the black tab away from the white plastic. This will loosen the tension on the brown cable allowing it to gently be slid away from the tab. Shown in the third picture, remove the 4 Phillips #1 screws connecting the circuit board to the optical drive assembly.
    • Remove the blue wire by gently pulling.
    • Disconnect the Brown cable. This is done by gently pulling the black tab away from the white plastic. This will loosen the tension on the brown cable allowing it to gently be slid away from the tab.
    • Shown in the third picture, remove the 4 Phillips #1 screws connecting the circuit board to the optical drive assembly.
    • The fourth screw is located behind the screwdriver in the third picture (highlighted in the orange circle).
  12. Gently remove the circuit board (the large green square) as shown in the three pictures. DO NOT SEPARATE the red wire or the white ribbon cable connecting the circuit board to the metal plate. Red Wire
    • Gently remove the circuit board (the large green square) as shown in the three pictures.
    • DO NOT SEPARATE the red wire or the white ribbon cable connecting the circuit board to the metal plate.
    • Red Wire
    • White ribbon Cable
    What would happen if I accidentally separated the white ribbon cable... because I watched a video of some guy going through this same process. Separated all the cables and his worked. My cube stopped reading disks recently. Laser is calibrated properly. Begins to spin then stops
    Ps
    Is there anyway I can save my cube
    kyleharms10 - Replica
    I'm just guessing here, but I think they mean there's no need to separate those cables to complete the repair—just be careful not to pull or stress them. Like you said, nothing bad will happen if you choose to disconnect a couple cables. As for what's wrong with your cube, you might want to try asking your question over in the Answers forum.
    Jeff Suovanen -
    There is a small tab to the left of the red wire that you need to pull out to release the circuit board.
    patriotsfansince87 - Replica
    Why do we need further disassembly that this ? The potentiometer is already accessible at this point. Why do we need to tear down the lens from it’s slot in step 16 ?
    Startide Harlock - Replica
  13. Use a flathead screwdriver to carefully release the four plastic clips holding the drive assembly together. The last clip can be rather hard to find. Carefully use a screwdriver as leverage to unscrew and release the last clip, which is highlighted in blue (Picture 3). The last clip can be rather hard to find. Carefully use a screwdriver as leverage to unscrew and release the last clip, which is highlighted in blue (Picture 3).
    • Use a flathead screwdriver to carefully release the four plastic clips holding the drive assembly together.
    • The last clip can be rather hard to find. Carefully use a screwdriver as leverage to unscrew and release the last clip, which is highlighted in blue (Picture 3).
  14. Gently lift the metal plate off of the drive assembly (shown in the first picture). Be careful not to sever the red wire or the white ribbon cable still attached to the two halves of the drive assembly. Then flip the two halves of the drive assembly upside down as shown in the third picture.
    • Gently lift the metal plate off of the drive assembly (shown in the first picture).
    • Be careful not to sever the red wire or the white ribbon cable still attached to the two halves of the drive assembly.
    • Then flip the two halves of the drive assembly upside down as shown in the third picture.
  15. Use a flathead screwdriver to release the two clips located on the back half of the drive assembly. The final clip doesn't need to be released; the top half of the drive assembly will slide away from the lower half. Finish removing the top half of the drive assembly from the base.
    • Use a flathead screwdriver to release the two clips located on the back half of the drive assembly.
    • The final clip doesn't need to be released; the top half of the drive assembly will slide away from the lower half.
    • Finish removing the top half of the drive assembly from the base.
    • Be careful not to detach the red wire or the white ribbon cable still attached.
  16. Once the top half of the drive assembly is detached, turn it upside down. Using a philips screwdriver, carefully remove the 3 final screws located near the bars of the lens assembly.
    • Once the top half of the drive assembly is detached, turn it upside down.
    • Using a philips screwdriver, carefully remove the 3 final screws located near the bars of the lens assembly.
    • Once the the three final screws are removed, the lens assembly can be extracted (as shown in the second picture).
    what kind of screws are these on the laser lens i lost one and need to buy new ones cause i cant find the 3rd
    Ugly potato - Replica
  17. Rotate the assembly so that the green circuit board is facing you as shown in the first picture. Flip board over so it is oriented as shown in the second picture.
    • Rotate the assembly so that the green circuit board is facing you as shown in the first picture.
    • Flip board over so it is oriented as shown in the second picture.
    • Using a Phillips #1 Screwdriver, turn the small knob very slightly counter-clockwise—a few degrees to, at most, one-quarter turn.
    • You can find instructions for testing to make sure your repair worked at this link.
    Isn't it supposed to be counter clockwise? I read somewhere that turning it clockwise weakens the laser.
    Daniel Cital - Replica
    Agreed, it should be counter-clockwise.
    Lauren - Replica
    Does anyone know the initial ohm potentiometer setting on Nintendo Gamecube DOL-001 (factory) on the pcb driver (RJB2281A-1 POT 0-900 OHM) THANK YOU
    Fanisrf Raptis - Replica
Conclusione
Altre 16 persone hanno completato questa guida.
agronbac
Membro da: 28/10/2009
640 Reputazione
1 Guida realizzata
Cal Poly, Team 6-2, Maness Fall 2009 Membro di Cal Poly, Team 6-2, Maness Fall 2009
CPSU-MANESS-F09S6G2
4 Membri
10 Guide realizzate
I don't understand why you have steps 11-17. In step 10, you can clearly see the board with the screw that needs adjusting. Taking apart the rest of the GameCube is utterly unnecessary. After following the guide in full, I thought, 'Why did I just dismantle all that other stuff when I didn't even NEED to?'
Once the assembly is removed from the metal covering the board, it is a simple matter to turn the screw to increase the laser strength. I did this after my initial adjustment didn't work. I ignored steps 11-17 and everything works perfectly now. My old games which simply would not load, now do. Thanks for the advice leading up to step 10 though. That part was helpful.
Johnny H - Replica
I wouldn't say it's a quarter of a turn, a few degrees clockwise do the trick. I tried a quarter of a turn the first time and it made the disk unit useless as it didn't recognise any gamecube disk.
Jaime Aluja - Replica
Thanks for the detailed pictures! I was able to get everything taken apart, and fixed the read error I was having after a couple of readjustments.
One important note: the lens screw should be turned counter-clockwise, not clockwise. A quarter turn is also likely to be too much; better to adjust a few degrees at a time and test repeatedly until the right setting is found.
gameFAQs.com has a lens calibration guide, with notes on how to reassemble the GameCube for testing without screwing everything back together.
I also agree that steps 11-17 can be skipped, as well as step 5 to remove the controller ports.
Lauren - Replica
Steps 11+ are definitely not needed and 1/4 turn is more than 200ohms, way too much. It has to be moved by a hair (almost literally), the potentiometer is extremely sensitive. And I would personally recommend some form of multimeter, as to not go turning that screw blindly.
Nicola Lahaie - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 20
Ultimi 7 Giorni: 172
Ultimi 30 Giorni: 727
Tutti i Tempi: 57,692
