Salta al contenuto principale
Opening the Galaxy Watch3
Cosa ti serve
  1. Opening the Galaxy Watch3, Unfasten the back cover screws: passo 1, immagine 1 di 1
    • Before starting repairs, take your watch off the charger and power it down.
    • Use a Tri-point Y00 driver to unfasten the four screws on the back of the watch.
    • Don’t worry about removing the screws, they will stay in place in the back cover.
    Chiedi a FixBot
    Aggiungi Commento
  2. Opening the Galaxy Watch3, Wedge open the back cover: passo 2, immagine 1 di 2 Opening the Galaxy Watch3, Wedge open the back cover: passo 2, immagine 2 di 2
    • Insert an opening tool between the back cover and the metal housing.
    • Twist the opening tool to create a wider gap.
    • Don't fully remove the back cover just yet. The sensor flex cable is still connected to the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  3. Opening the Galaxy Watch3, Disconnect the sensor flex cable: passo 3, immagine 1 di 3 Opening the Galaxy Watch3, Disconnect the sensor flex cable: passo 3, immagine 2 di 3 Opening the Galaxy Watch3, Disconnect the sensor flex cable: passo 3, immagine 3 di 3
    • Lay the watch face down.
    • Carefully lift the back cover up from the edge with the buttons to access the sensor connector.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  4. Opening the Galaxy Watch3, Remove the back cover: passo 4, immagine 1 di 2 Opening the Galaxy Watch3, Remove the back cover: passo 4, immagine 2 di 2
    • Remove the back cover.
    • Make sure the rubber gasket (marked red) is undamaged. If damaged replace it with a new one during reassembly to maintain proper water resistance.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Tobias Isakeit
Membro da: 03/31/14
133.742 Reputazione
189 guide realizzate
Tobias Isakeit - Repairability Engineer Membro di Tobias Isakeit - Repairability Engineer
Business
Membro di 1
1.145 guide realizzate
5Commenti sulla guida
where can I get the galaxy watch3 rubber gasket?
regards
Miguel Vera - Rispondi Condividi
That’s a good question. As for the previous models it is very hard to find those rubber gaskets. Using a “liquid rubber gasket” might be one solution to that. (Use carefully to not spill too much on and into the watch)
Tobias Isakeit - Rispondi Condividi
I tried to remove all of the screws from the back cover, but 3 of the 4 screws remained and seemed to be fused to the main base of the watch. One of the screws was stripped. Now only 1 screw is engaged with the back cover. (I might need to replace the back cover. My watch is glitching which is draining the battery. I would like to fix the problems myself. Where can I get specific advice?
Antoinette - Rispondi Condividi
Hallo Hallo..Ich kann gar nicht offnen galaxy watch 4 classic.Fast alle schraube dreher gekauft aber für nichts einfach geht nicht raus schraube.wollte ich akku wechseln..kann mir jemand helfen?
Danke
maia margishvili - Rispondi Condividi
@isakrittl Du schreibst: "Achte darauf, dass die Gummidichtung (rot markiert) in Ordnung ist. Falls sie beschädigt ist, ersetze sie beim Zusammenbau durch eine neue, damit die Uhr wasserdicht bleibt."
Wo bekomme ich denn eine neue her? Hab nirgends eine gefunden... Danke!
Steffen Politzky - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 29
Ultimi 30 giorni: 109
Tutti i Tempi: 4,760
