Cosa ti serve
open Anaconda Navigator
launch Spyder
click 'Open File' and select "node_builder.py" under "\Documents\anvil"
click the 'Run' button
visit this link to get started: Node Builder
Obtain a solar panel with the appropriate metal plate.
Obtain the correctly bend metal plate.
Obtain the enclosure with the predrilled holes.
Obtain the solar panel extension cable
Obtain heat-shrink tubing and place it around the cable
Cover the connection between the solar panel wire and the extension cable with the heat-shrink tubing. Then, use a heat gun to shrink the tubing, creating a water-tight seal around the connection
Trim the solar panel extension wire so there is approximately 20 inches of wire from the connection point
Strip the wires as shown in the image
Twist the ends of the wires
Attach the solar panel onto the metal plate.
Using screws and a screw driver, screw the solar panel into these holes. Now that the solar panel is attached to the metal plate, attach the metal plate onto the lid of the enclosure
Note: the tall side of the metal plate should be on the same side of the enclosure as the holes for the ultrasonic sensor and cable glands.
The screws and nuts should be screwed in this matter in the holes on the sides of the box lid (meaning the nut is on the outside)
Obtain velcro
Add velcro with soft side inside the enclosure in the following places
Obtain a cable gland
Screw the cable gland into the wall of the enclosure, through the small hole, as shown
Place an o-ring between the cable gland and outer-wall of the enclosure
Insert the solar panel extension wire into the cable gland as shown, leaving approximately 8 inches of wire inside the enclosure
Obtain a plugable header and ensure the ends of the wires are twisted
Screw the wires into the plugable header as shown in the picture
Solder a 3-prong terminal block to the ground, power, and data (#5) through-holes on the depth sensor
For organization, bind three wires (red, white, and black) with a small piece of shrink wrap
Connect the wires as shown in the picture (black to ground, red to power, white for data)
Assemble the depth sensor by adding the o-rings, and the connective wires in the order pictured, leaving the nut ring to the side
Note that the connective wires connect the depth sensor to the sensor node board. Remember, red wire is responsible for power, black is for ground, and white is for data
Place the depth sensor through the larger hole, and secure it firmly by tightening the nut ring
Obtain the cell module (modem), GPS, and antenna
Insert Super SIM card into cell module
Attach the GPS to the connection shown (grey wire)
Attach the antenna to the connection shown (black wire)
Attach rough-sided velcro on the antenna and GPS as shown in the picture.
Obtain velcro and lithium ion 3.7V battery. Attach rough side of velcro on battery
Obtain a block plug.
Twist the wires of the battery so they fit nicely in the plugable-header block
Screw the wires into the block plug
Obtain one battery, 4 zip ties, foam, and a pair of scissors
Cut out two battery-sized pieces of foam
Sandwich the battery between the two pieces of foam and secure it using the zip-ties. Connect the zip-ties to make two extra long zip-ties
Obtain eight 1.5-inch long standoffs. Screw the standoffs together as shown, to make four 3-inch long standoffs
Screw the standoffs into the enclosure
Insert battery into the enclosure. Make sure the wire is on the sensor-side of the enclosure
Obtain Open-Storm board and place 4 jumpers in the spots shown
Insert microSD card into board
Attach the cellular module onto the sensor node board in the appropriate place
Put the board on top of the standoffs in the enclosure, and screw it in using a screw driver
Connect the depth sensor wire as shown
Connect the solar panel wire to the board as shown
Connect the battery wire to the board as shown
Attach the antenna, and the GPS on the velcro to the closest wall on the inside of the enclosure
apply the open-storm sticker to the side of the enclosure as shown
apply the unique node ID sticker to the two spots shown
print a label with the unique node ID that appears on the sticker using the label maker
apply the label to the board as shown
Fold wire over itself so that the portion above the hose clamp won't have slack when the black wire section is pressed against the inside of the panel
Obtain a hose clamp, and secure the red part of the wire to the black section using a drill fitted with the drill bit
Wrap a zip tie around the wire as shown.
Use a second zip tie to connect the ends of the first one
Use a clamp to tighten the zip tie
Position each zip tie head as shown while tightening
Clip excess zip tie as close as possible
Obtain USB power supply, plug into a laptop, and set output to 5.9V
Plug in the green terminal block from the power supply into the Open-Storm board solar port.
Confirm the solar charge LED is off.
Plug in a dead battery to the battery port. This step will not work with a charged battery
CAREFULLY turn the silver potentiometer next to the charge controller IC with a small flathead screw driver until the charge light turns on.
obtain a master lock and a pair of scissors
cut the lock and key out of the packaging
set the lock to the default combination, 0-0-0-0, open the lock
put the key into the lock and twist clockwise 90 degrees
while the key is still twisted, set the combo to 2-2-4-5
remove the key, and the lock is ready to go
obtain the materials in the quantities shown
screw the U-bracket onto one of the 8" strut channels, using one of the 1/2" hex bolts and the 1/2" strut channel nut
attach the remaining 8" strut channel piece to the U-bracket, using two 1/2" hex bolts and two 1/2" hex nuts
be sure not to center the strut channel you are attaching the the U-bracket, instead make one side of the U-bracket flush with end of the strut channel (as shown)
insert the two 5/16" strut channel nuts into the back of the horizontal strut channel as shown
attach the winged strut channel bracket to the 8" telespar using the remaining two hex bolts and hex nuts
when tightening the hex nuts, ensure the edge of the nut points directly outwards (as shown), or else the struct channel piece will not slide inside
confirm the T-shaped strut channel piece slides into the telespar, and the handle is now finished
Attach the reinforcement rails to the back of the node using two 5/16" hex bolts, two 5/16" hex bolts, and two 5/16" 1.25" OD washers. Insert the bolts the bottom two holes of the node enclosure, using the bottom holes of the rails as shown in the image.
Line up the top holes of the rails with the top node enclosure holes and then tighten the bottom bolts.
screw the node enclosure onto the strut channel using the two 5/16" hex bolts and two 5/16" 1.5"OD washers. Be sure to put bolts through the reinforcement rails.
slide the T-shaped piece back into the telespar
this is what the node should look like on the inside
attach the lock to the outside of the enclosure
return to Node Builder for instructions on how to drop off the node at the testing rack
Altre 3 persone hanno completato questa guida.
