1. Make sure you have the following:
    • Make sure you have the following:
    • Real-Time Water Systems Cell Board
    • PSoC USB connector
    • Maxbotix Sonar Depth Sensor
    • SM3 Soil Moisture Probe
    • Pressure Transducer.
  2. In order to use the Open-Storm Cell Board, you need to connect certain pins on the board by using jumpers.
    • In order to use the Open-Storm Cell Board, you need to connect certain pins on the board by using jumpers.
    • Jumps are black, and connect two pins.
    • Jumpers allow users to toggle options on the board, such as power supply voltage or making it possible for the Cell Board to be programmed using PSoC software.
    • See pictures for proper orientation of jumpers on pins.
    • First screw in the wires into the ultrasonic sensor
    • Next screw in the wires into a terminal block
    • Then insert the terminal block into the board as shown
    • Pay careful attention to the pin locations on the board.
    • Soil Moisture and Pressure transducer share the same supply voltage, therefore you will need to take care to connect them at the same time.
    • See next step for complete connections.
    • Jumper wire provides power to pressure transducer.
    • Connect PSoC USB connector to board.
    • Connection is uni-directional. Take care that it is properly connected before inserting USB side into computer.
    • Make sure you have the proper connections between your board and the USB. Check that the white connector is seated correctly.
Linea Traguardo
Gregory Ewing
Membro da: 12/06/2018
229 Reputazione
2 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 24
