Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
Replace the power fuse for the Onkyo TX800 receiver.
  1. Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place. Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place. Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place.
    • Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place.
  2. Remove the top screw on the back panel. Remove the top screw on the back panel.
    • Remove the top screw on the back panel.
  3. LCD iPhone Screen Fix Kits
    The budget option, covered by our Lifetime Warranty.
    Shop Kits
    Cut repair costs, not quality.
    Shop Kits
  4. Slide off the case to expose the internal components of the receiver. Slide off the case to expose the internal components of the receiver.
    • Slide off the case to expose the internal components of the receiver.
  5. Locate the fuse. Locate the fuse.
    • Locate the fuse.
  6. Gently wedge a small screwdriver in between one side of the fuse and the contact. Remove the fuse with your thumb and forefinger.
    • Gently wedge a small screwdriver in between one side of the fuse and the contact.
    • Remove the fuse with your thumb and forefinger.
  7. Examine the fuse. If the wire within it is broken, you will need to replace it with a new 125 Volt, 4 Amp fuse.
    • Examine the fuse. If the wire within it is broken, you will need to replace it with a new 125 Volt, 4 Amp fuse.
Linea Traguardo
Altre 4 persone hanno completato questa guida.
Michael Lady
Membro da: 09/04/2010
244 Reputazione
2 Guide realizzate
Cal Poly, Team 27-92, Amido Spring 2010 Membro di Cal Poly, Team 27-92, Amido Spring 2010
CPSU-AMIDO-S10S27G92
4 Membri
7 Guide realizzate
Thanks for clear instructions!
Andy Dersch - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 47
Ultimi 30 Giorni: 226
Tutti i Tempi: 10,920
