Salta al contenuto principale
Panoramica Video
Questo smontaggio non è una guida di riparazione. Per riparare il tuo OnePlus 7 Pro, usa il nostro manuale di assistenza.
    Considerazioni Finali
    • The battery can be removed first, once you open the phone. It’s only lightly adhered and comes with a pull tab for easy removal.
    • Many components are modular and can be individually replaced.
    • Display replacements, which are the most common repairs, are not prioritized in the design. (You have to completely disassemble the phone to swap out your screen.)
    • While the Front Facing Camera’s new pop up ability is really cool, the added mechanical element makes it more likely to wear out and more complicated to replace.
    • The primary access point for all repairs, the rear panel, is firmly glued in place.
    Punteggio Riparabilità
    4
    Riparabilità 4 su 10
    (10 è il più facile da riparare)
6Commenti sulla guida
What is the best way to get rid of slider?
Can it be cut from outside w/o unglue back cover?
Bob Monkas - Replica Condividi
Slider? Do you mean the pop up camera? If so, removing it is major surgery, cannot be done from the outside.
Forge - Condividi
Can I replace the 256 memory module? Need to salvage some things on it.
vishal.shah.tx - Replica Condividi
OnePlus 7 pro 8/256
Anita Jajoriya - Condividi
do i need to remove the pop up camera if i want to change the screen?
romain.collet - Replica Condividi
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 46
Ultimi 30 Giorni: 179
Tutti i Tempi: 75,856
