Introduzione
If the audio coming from your OnePlus 6T speakers sounds distorted and troubleshooting doesn’t work, you may need to replace your speakers.
Cosa ti serve
Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
Attrezzo utilizzato in questo passaggio:Plastic Cards$2.99
Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
Remove the back cover from the phone.
Altre 7 persone hanno completato questa guida.
