Introduzione
OnePlus 6T was the flagship killer launched by the Chinese brand in November 2018. One of the major upgrades from its OnePlus 6 model, was the in-screen fingerprint scanner alongside other hardware updates. 6T featured a dual-camera setup at the rear (16+20 MP) and was the best camera launched by the company until the OnePlus 7 in the following year. This post helps you replace that setup and its detailed explanation ensures that you perform this procedure in the best way possible.
Cosa ti serve
Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
Attrezzo utilizzato in questo passaggio:Plastic Cards$2.99
Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
Remove the back cover from the phone.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Remove the single 3mm Phillips #00 screws holding the metal battery cover on the phone.
Use tweezers to remove the battery cover and place it to the side.
Remove the single 3mm Phillips #00 screw to the right of the top rear camera.
Using a spudger, disconnect the two metal rear camera tabs on the left side of the camera.
Remove the camera from its slot on the motherboard.
Altre 3 persone hanno completato questa guida.
