Salta al contenuto principale
OnePlus 6T Front Camera Replacement
Cosa ti serve
  1. OnePlus 6T Front Camera Replacement, Back Cover: passo 1, immagine 1 di 1
    • Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
  2. OnePlus 6T Front Camera Replacement: passo 2, immagine 1 di 1
    • Pop open the SIM card tray by inserting a SIM card removal tool into a small hole on the upper-left side of the phone.
    • Carefully remove the SIM card from its tray.
  3. OnePlus 6T Front Camera Replacement: passo 3, immagine 1 di 1
    • Loosen the binding glue within the phone using a hairdryer or an iOpener.
    • If you choose to use a hairdryer, hold the dryer at least eight inches from the phone and apply heat for two minutes in a circular motion around the edges of the phone.
  4. OnePlus 6T Front Camera Replacement: passo 4, immagine 1 di 3 OnePlus 6T Front Camera Replacement: passo 4, immagine 2 di 3 OnePlus 6T Front Camera Replacement: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Plastic Cards
    $2.99
    Compra
    • Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
    • Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
    • There will be a small amount of tension, but this is normal as the card is removing the adhesive within the phone.
    • Remove the back cover from the phone.
    • Use high concentration (>90%) isopropyl alcohol and a lint-free cloth to remove all adhesive residue from the back cover and the frame.
  5. OnePlus 6T Front Camera Replacement, Front Camera: passo 5, immagine 1 di 2 OnePlus 6T Front Camera Replacement, Front Camera: passo 5, immagine 2 di 2
    • Remove the single 3mm Phillips #00 screws holding the metal battery cover on the phone.
    • Use tweezers to remove the battery cover and place it to the side.
  6. OnePlus 6T Front Camera Replacement: passo 6, immagine 1 di 1
    • Remove eight 3mm Phillips #00 screws that connect the midframe to the phone.
  7. OnePlus 6T Front Camera Replacement: passo 7, immagine 1 di 1
    • Using a spudger, gently remove the midframe and place it to the side.
  8. OnePlus 6T Front Camera Replacement: passo 8, immagine 1 di 1
    • Using a spudger, lift the light brown tab in the middle of phone to disconnect the front camera.
    • Remove the front camera from the phone.
Conclusione
Altre 2 persone hanno completato questa guida.
Kristen Gismondi
Membro da: 11/12/14
81.669 Reputazione
200 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
16.734 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 31
Tutti i Tempi: 1,091
