Introduzione
If your OnePlus 6T is experiencing battery drainage issues or won’t hold a charge/won’t charge, then it may be time to replace the phone’s battery.
Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
Altre 8 persone hanno completato questa guida.
3 Commenti
Does the adhesive for the back cover need to be replaced? Should I heat the phone and back glass for re-assembly?
Good questions. I think “reassembly is the reverse of these instructions" is a bit simplified. I think the heat is only for removal, but perhaps it would cause the adhesive to rebond after reassembly? Can an ifixit tech comment?
Just wondering if anyone can clarify the reattachment of the rear panel, as far as whether it is recommended, or necessary, to heat it again, or get a new adhesive gasket. Thanks.
