Salta al contenuto principale
OnePlus 6 or 6T Alert Slider Cleaning
Cosa ti serve
  1. OnePlus 6 or 6T Alert Slider Cleaning, The problem: passo 1, immagine 1 di 3 OnePlus 6 or 6T Alert Slider Cleaning, The problem: passo 1, immagine 2 di 3 OnePlus 6 or 6T Alert Slider Cleaning, The problem: passo 1, immagine 3 di 3
    • Although the three distinct slider positions are set, the phone only recognizes two of them.
  2. OnePlus 6 or 6T Alert Slider Cleaning, Clean the slider: passo 2, immagine 1 di 2 OnePlus 6 or 6T Alert Slider Cleaning, Clean the slider: passo 2, immagine 2 di 2
    • Use a small tool to clean up the two different sides: the slider side and the top side.
    • Be careful not to scratch the side of the phone. A soft-tipped tool, like the iFixit spudger, is ideal.
  3. OnePlus 6 or 6T Alert Slider Cleaning, Clean the other sides as well!: passo 3, immagine 1 di 1
    • Clean the other two sides as well to prevent the same issue from occurring.
Conclusione
If you cannot remove more dust from the slider then it should be fixed. Try moving it to the other positions and feel whether the slider clicks into the positions. If the slider is still not functioning correctly, then perhaps a replacement of the slider is necessary. A replacement guide for the older OnePlus 5T can be found here.
Altre 2 persone hanno completato questa guida.
Martin Muller
Membro da: 02/24/21
231 Reputazione
1 Guida realizzata
1Commento della guida
Thank you boss. you are a lifesaver !!! Just now did it. I have been troubled by this for more than a year.. Now it's working good as new.. Thanks a lot !!
Mahesh Lal - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 30
Tutti i Tempi: 3,481
