Salta al contenuto principale
OnePlus 3 USB Type-C Port Replacement
Cosa ti serve
Istruzioni Video
Conclusione
Altre 25 persone hanno completato questa guida.
Witrigs
Membro da: 11/24/15
69.157 Reputazione
378 Guide realizzate
14 Commenti
I broke 5 spudgers getting the screen to separate from the back because dirt had built up around the edge this is also the reason the usb port died. consider buying extra spudgers when doing your repair.
RayZ fox - Replica
consider keeping your phone clean.
MO MOBILE - Replica
Is the same charging port used on the 3T?
thisisian - Replica
I successfully followed this guide, to replace the charging port on an UK 3T phone (it seems like the same part, I bought it on ebay).
The hardest part was getting the first spudger into the phone case, which took me at least 20 minutes (first time trying this). As noted make sure you have spares.
I had a little trouble reconnecting the lower round gold power connector as the cable had shifted a bit during taking out the component it connects to and it was very sensitive to position to go in right.
Having the high quality driver set from ifixit made a huge difference as I’d have spent ages fiddling if the driver was not magnetized for lifting the tiny screws in and out.
Steve -
Perfect ! +-20 min. just be sure to check the rubber of the charging port and aux cable are in the right position before placing the cover back
Yorgi D'Haese - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 26
Tutti i Tempi: 25,179
