Salta al contenuto principale
One Education Infinity:One Hinge Contact Assembly Replacement
Cosa ti serve
  1. One Education Infinity:One Hinge Contact Assembly Replacement, Back Case: passo 1, immagine 1 di 2 One Education Infinity:One Hinge Contact Assembly Replacement, Back Case: passo 1, immagine 2 di 2
    • Use a spudger to pry the four rubber pads away from the bottom of the case.
    • Use a Phillips #00 screwdriver to unscrew the four 6.4 mm screws.
  2. One Education Infinity:One Hinge Contact Assembly Replacement: passo 2, immagine 1 di 2 One Education Infinity:One Hinge Contact Assembly Replacement: passo 2, immagine 2 di 2
    • Insert a Jimmy or other prying tool into the seam on the edge of the casing.
    • Trace along the edges of the device until all clips are released.
    • Lift the back case away from the device.
  3. One Education Infinity:One Hinge Contact Assembly Replacement: passo 3, immagine 1 di 1
    • Use a Phillips #00 screwdriver to unscrew the four 6.4mm screws on the hinge mounts.
  4. One Education Infinity:One Hinge Contact Assembly Replacement: passo 4, immagine 1 di 2 One Education Infinity:One Hinge Contact Assembly Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Use tweezers to lift the fabric cover and hinge connector away from the daughterboard.
    • Always use ESD safe tools when working with delicate electrical components.
  5. One Education Infinity:One Hinge Contact Assembly Replacement, Hinge Contact Assembly: passo 5, immagine 1 di 2 One Education Infinity:One Hinge Contact Assembly Replacement, Hinge Contact Assembly: passo 5, immagine 2 di 2
    • Lift the hinge away from the device.
  6. One Education Infinity:One Hinge Contact Assembly Replacement: passo 6, immagine 1 di 1
    • Use a Phillips #00 screwdriver to unscrew the two 6.5mm screws.
  7. One Education Infinity:One Hinge Contact Assembly Replacement: passo 7, immagine 1 di 2 One Education Infinity:One Hinge Contact Assembly Replacement: passo 7, immagine 2 di 2
    • Slide a Jimmy or other prying tool along the seam of the hinge to pry the casing apart.
  8. One Education Infinity:One Hinge Contact Assembly Replacement: passo 8, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the two 4.3mm screws holding the circuit board in place.
  9. One Education Infinity:One Hinge Contact Assembly Replacement: passo 9, immagine 1 di 1
    • Use a spudger to pry the circuit board away from the casing.
    • Always use ESD safe tools when removing delicate components.
Conclusione
1Commento della guida
Everything is very detailed and shown. Everything is also done in detail on this site ++https://oceanessay.com/buy-thesis-pape... , which helps students learn. There you will find a lot of educational materials.
Nathan Joyce - Replica Condividi
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 56
Tutti i Tempi: 478
