Salta al contenuto principale
One Education Infinity:One Dock Contact Assembly Replacement
Cosa ti serve
  1. One Education Infinity:One Dock Contact Assembly Replacement, Battery: passo 1, immagine 1 di 2 One Education Infinity:One Dock Contact Assembly Replacement, Battery: passo 1, immagine 2 di 2
    • Use a spudger to disconnect the black bundled cable connector from the motherboard.
  2. One Education Infinity:One Dock Contact Assembly Replacement: passo 2, immagine 1 di 3 One Education Infinity:One Dock Contact Assembly Replacement: passo 2, immagine 2 di 3 One Education Infinity:One Dock Contact Assembly Replacement: passo 2, immagine 3 di 3
    • Use a spudger to lift the black tab on top of the ZIF connector.
    • Slide the ribbon cable out of the connector.
  3. One Education Infinity:One Dock Contact Assembly Replacement: passo 3, immagine 1 di 3 One Education Infinity:One Dock Contact Assembly Replacement: passo 3, immagine 2 di 3 One Education Infinity:One Dock Contact Assembly Replacement: passo 3, immagine 3 di 3
    • Use a spudger to flip up the black retaining flap on the ZIF connector.
    • Pull the folded ribbon cable straight out of the connector.
    • This ribbon cable must be disconnected before removing the battery because it is attached to the battery with adhesive.
  4. One Education Infinity:One Dock Contact Assembly Replacement: passo 4, immagine 1 di 1
    • Use a spudger to pry the battery away from the device.
    • Always use ESD safe tools when working with delicate electrical components.
  5. One Education Infinity:One Dock Contact Assembly Replacement, Dock Contact Assembly: passo 5, immagine 1 di 1
    • Use tweezers to pull the dock contact display cable away from the connector on the motherboard.
  6. One Education Infinity:One Dock Contact Assembly Replacement: passo 6, immagine 1 di 1
    • Use a Phillips #000 screwdriver to unscrew the two 4.2mm screws from the circuit board containing the dock contact.
  7. One Education Infinity:One Dock Contact Assembly Replacement: passo 7, immagine 1 di 1
    • Lift the dock contact assembly away from the device.
Conclusione
Taylor Bratsch
Membro da: 09/06/16
5.742 Reputazione
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 150
