Salta al contenuto principale
One Education Infinity:One Display Assembly Replacement
Cosa ti serve
  1. One Education Infinity:One Display Assembly Replacement, Top Case: passo 1, immagine 1 di 3 One Education Infinity:One Display Assembly Replacement, Top Case: passo 1, immagine 2 di 3 One Education Infinity:One Display Assembly Replacement, Top Case: passo 1, immagine 3 di 3
    • Insert a Jimmy or other prying tool into the seam between the screen and back case.
    • Trace around the edges until all clips are released.
    • Lift the back case away from the tablet.
  2. One Education Infinity:One Display Assembly Replacement, Speaker: passo 2, immagine 1 di 2 One Education Infinity:One Display Assembly Replacement, Speaker: passo 2, immagine 2 di 2
    • Use a spudger to release the speaker wires by pushing the bundled cabled connector away from the motherboard.
    • Be sure to pull out the white connector instead of the individual wires to avoid damage to the device.
  3. One Education Infinity:One Display Assembly Replacement: passo 3, immagine 1 di 1
    • Use a spudger to lift the speakers out of the device.
  4. One Education Infinity:One Display Assembly Replacement, Battery: passo 4, immagine 1 di 2 One Education Infinity:One Display Assembly Replacement, Battery: passo 4, immagine 2 di 2
    • Use a spudger to disconnect the black bundled cable connector from the motherboard.
  5. One Education Infinity:One Display Assembly Replacement: passo 5, immagine 1 di 3 One Education Infinity:One Display Assembly Replacement: passo 5, immagine 2 di 3 One Education Infinity:One Display Assembly Replacement: passo 5, immagine 3 di 3
    • Use a spudger to lift the black tab on top of the ZIF connector.
    • Slide the ribbon cable out of the connector.
  6. One Education Infinity:One Display Assembly Replacement: passo 6, immagine 1 di 3 One Education Infinity:One Display Assembly Replacement: passo 6, immagine 2 di 3 One Education Infinity:One Display Assembly Replacement: passo 6, immagine 3 di 3
    • Use a spudger to flip up the black retaining flap on the ZIF connector.
    • Pull the folded ribbon cable straight out of the connector.
    • This ribbon cable must be disconnected before removing the battery because it is attached to the battery with adhesive.
  7. One Education Infinity:One Display Assembly Replacement: passo 7, immagine 1 di 1
    • Use a spudger to pry the battery away from the device.
    • Always use ESD safe tools when working with delicate electrical components.
  8. One Education Infinity:One Display Assembly Replacement, Antenna: passo 8, immagine 1 di 2 One Education Infinity:One Display Assembly Replacement, Antenna: passo 8, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Use ESD safe tweezers to disconnect the antenna from the motherboard.
  9. One Education Infinity:One Display Assembly Replacement, Camera Assembly: passo 9, immagine 1 di 3 One Education Infinity:One Display Assembly Replacement, Camera Assembly: passo 9, immagine 2 di 3 One Education Infinity:One Display Assembly Replacement, Camera Assembly: passo 9, immagine 3 di 3
    • Use a spudger to flip up the black flap on the camera's ZIF connector.
    • Pull the ribbon cable straight out of the connector.
  10. One Education Infinity:One Display Assembly Replacement: passo 10, immagine 1 di 2 One Education Infinity:One Display Assembly Replacement: passo 10, immagine 2 di 2
    • Use tweezers to remove the black cushion surrounding the camera lens.
  11. One Education Infinity:One Display Assembly Replacement: passo 11, immagine 1 di 2 One Education Infinity:One Display Assembly Replacement: passo 11, immagine 2 di 2
    • Use tweezers to lift the camera assembly away from the device.
    • Lift straight up to avoid tearing the delicate ribbon cable on the retaining wall.
  12. One Education Infinity:One Display Assembly Replacement, Motherboard: passo 12, immagine 1 di 3 One Education Infinity:One Display Assembly Replacement, Motherboard: passo 12, immagine 2 di 3 One Education Infinity:One Display Assembly Replacement, Motherboard: passo 12, immagine 3 di 3
  13. One Education Infinity:One Display Assembly Replacement: passo 13, immagine 1 di 1
    • Use tweezers to pull the dock connection cable away from the motherboard.
  14. One Education Infinity:One Display Assembly Replacement: passo 14, immagine 1 di 1
    • Use a Phillips #00 screwdriver to unscrew the two 3.4 mm screws.
    • Use a Phillips #000 screwdriver to unscrew the one 4.2mm screw.
  15. One Education Infinity:One Display Assembly Replacement: passo 15, immagine 1 di 1
    • Lift the protective shield away from the motherboard.
  16. One Education Infinity:One Display Assembly Replacement: passo 16, immagine 1 di 3 One Education Infinity:One Display Assembly Replacement: passo 16, immagine 2 di 3 One Education Infinity:One Display Assembly Replacement: passo 16, immagine 3 di 3
    • With the flat end of a spudger, flip up the black flap on the display's ZIF connector.
    • Insert the pointed end of the spudger between the cable and the motherboard and gently pull the cable straight out of the connector.
    • During reassembly, be sure to insert the cable into the connector up to the white line on the cable and then close the retaining flap.
  17. One Education Infinity:One Display Assembly Replacement: passo 17, immagine 1 di 1
    • Gently lift the motherboard away from the display assembly.
  18. One Education Infinity:One Display Assembly Replacement, Display Assembly: passo 18, immagine 1 di 1
    • Unscrew the five 4.2mm screws with a Phillips #000 screwdriver.
  19. One Education Infinity:One Display Assembly Replacement: passo 19, immagine 1 di 2 One Education Infinity:One Display Assembly Replacement: passo 19, immagine 2 di 2
    • Peel the protective flap away from the display.
  20. One Education Infinity:One Display Assembly Replacement: passo 20, immagine 1 di 2 One Education Infinity:One Display Assembly Replacement: passo 20, immagine 2 di 2
    • Use a spudger to lift the digitizer away from the screen.
    • Grasp the edge of the digitizer and lift straight up to remove.
Conclusione
Taylor Bratsch
Membro da: 09/06/16
6.083 Reputazione
14 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 415
