Salta al contenuto principale
One Education Infinity:One Daughterboard Replacement
Cosa ti serve
  1. One Education Infinity:One Daughterboard Replacement, Back Case: passo 1, immagine 1 di 2 One Education Infinity:One Daughterboard Replacement, Back Case: passo 1, immagine 2 di 2
    • Use a spudger to pry the four rubber pads away from the bottom of the case.
    • Use a Phillips #00 screwdriver to unscrew the four 6.4 mm screws.
  2. One Education Infinity:One Daughterboard Replacement: passo 2, immagine 1 di 2 One Education Infinity:One Daughterboard Replacement: passo 2, immagine 2 di 2
    • Insert a Jimmy or other prying tool into the seam on the edge of the casing.
    • Trace along the edges of the device until all clips are released.
    • Lift the back case away from the device.
  3. One Education Infinity:One Daughterboard Replacement: passo 3, immagine 1 di 1
    • Use a Phillips #00 screwdriver to unscrew the four 6.4mm screws on the hinge mounts.
  4. One Education Infinity:One Daughterboard Replacement: passo 4, immagine 1 di 2 One Education Infinity:One Daughterboard Replacement: passo 4, immagine 2 di 2
    • Use tweezers to lift the fabric cover and hinge connector away from the daughterboard.
    • Always use ESD safe tools when working with delicate electrical components.
  5. One Education Infinity:One Daughterboard Replacement, Daughterboard: passo 5, immagine 1 di 2 One Education Infinity:One Daughterboard Replacement, Daughterboard: passo 5, immagine 2 di 2
    • Flip up the black retaining flap on the ZIF connector holding the large grey ribbon cable in place.
    • Pull the ribbon cable straight out of the ZIF connector.
  6. One Education Infinity:One Daughterboard Replacement: passo 6, immagine 1 di 2 One Education Infinity:One Daughterboard Replacement: passo 6, immagine 2 di 2
    • Use the flat end of a spudger to flip up the black tab on the smaller ZIF connector.
    • Use tweezers to pull the ribbon cable straight out of the connector.
  7. One Education Infinity:One Daughterboard Replacement: passo 7, immagine 1 di 3 One Education Infinity:One Daughterboard Replacement: passo 7, immagine 2 di 3 One Education Infinity:One Daughterboard Replacement: passo 7, immagine 3 di 3
    • Use a Phillips #000 screwdriver to unscrew the three 3.4mm screws.
    • Lift the daughterboard away from the device to remove.
Conclusione
Taylor Bratsch
Membro da: 09/06/16
5.742 Reputazione
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 245
