Salta al contenuto principale
One Education Infinity:One Battery Replacement
Cosa ti serve
  1. One Education Infinity:One Battery Replacement, Top Case: passo 1, immagine 1 di 3 One Education Infinity:One Battery Replacement, Top Case: passo 1, immagine 2 di 3 One Education Infinity:One Battery Replacement, Top Case: passo 1, immagine 3 di 3
    • Insert a Jimmy or other prying tool into the seam between the screen and back case.
    • Trace around the edges until all clips are released.
    • Lift the back case away from the tablet.
  2. One Education Infinity:One Battery Replacement, Battery: passo 2, immagine 1 di 2 One Education Infinity:One Battery Replacement, Battery: passo 2, immagine 2 di 2
    • Use a spudger to disconnect the black bundled cable connector from the motherboard.
  3. One Education Infinity:One Battery Replacement: passo 3, immagine 1 di 3 One Education Infinity:One Battery Replacement: passo 3, immagine 2 di 3 One Education Infinity:One Battery Replacement: passo 3, immagine 3 di 3
    • Use a spudger to lift the black tab on top of the ZIF connector.
    • Slide the ribbon cable out of the connector.
  4. One Education Infinity:One Battery Replacement: passo 4, immagine 1 di 3 One Education Infinity:One Battery Replacement: passo 4, immagine 2 di 3 One Education Infinity:One Battery Replacement: passo 4, immagine 3 di 3
    • Use a spudger to flip up the black retaining flap on the ZIF connector.
    • Pull the folded ribbon cable straight out of the connector.
    • This ribbon cable must be disconnected before removing the battery because it is attached to the battery with adhesive.
  5. One Education Infinity:One Battery Replacement: passo 5, immagine 1 di 1
    • Use a spudger to pry the battery away from the device.
    • Always use ESD safe tools when working with delicate electrical components.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 35
Tutti i Tempi: 1,277
