Salta al contenuto principale
One Education Infinity Solid State Drive Replacement
Cosa ti serve
  1. One Education Infinity Solid State Drive Replacement, Back Case: passo 1, immagine 1 di 3 One Education Infinity Solid State Drive Replacement, Back Case: passo 1, immagine 2 di 3 One Education Infinity Solid State Drive Replacement, Back Case: passo 1, immagine 3 di 3
    • Always power off your device before beginning disassembly.
    • Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
  2. One Education Infinity Solid State Drive Replacement: passo 2, immagine 1 di 2 One Education Infinity Solid State Drive Replacement: passo 2, immagine 2 di 2
    • Using a Phillips #00 screwdriver, remove the sixteen 5.0 mm black screws from the back panel.
  3. One Education Infinity Solid State Drive Replacement: passo 3, immagine 1 di 3 One Education Infinity Solid State Drive Replacement: passo 3, immagine 2 di 3 One Education Infinity Solid State Drive Replacement: passo 3, immagine 3 di 3
    • Using the iFixit plastic opening tool or spudger, start near the white hinge of the device and lift along the outer edges of the device until all clips are released.
    • Lift the back case off of the device.
    • Removing the back may create a loud snapping noise.
  4. One Education Infinity Solid State Drive Replacement, Battery: passo 4, immagine 1 di 3 One Education Infinity Solid State Drive Replacement, Battery: passo 4, immagine 2 di 3 One Education Infinity Solid State Drive Replacement, Battery: passo 4, immagine 3 di 3
    • There may be black tape inside your device covering components or holding down wires. This tape is unimportant for the function of the device, and can be removed.
    • Carefully wiggle the battery cable to the right and out of the port with a plastic spudger.
  5. One Education Infinity Solid State Drive Replacement: passo 5, immagine 1 di 3 One Education Infinity Solid State Drive Replacement: passo 5, immagine 2 di 3 One Education Infinity Solid State Drive Replacement: passo 5, immagine 3 di 3
    • Wedge a plastic spudger underneath the battery from the upper edge and slide it carefully along the length of the battery to separate it from the case.
    • There is a mild adhesive holding down the battery. Take care not to puncture or excessively bend the battery while freeing it from the adhesive.
    • Lift the battery out from the internal case.
  6. One Education Infinity Solid State Drive Replacement, Solid State Drive: passo 6, immagine 1 di 3 One Education Infinity Solid State Drive Replacement, Solid State Drive: passo 6, immagine 2 di 3 One Education Infinity Solid State Drive Replacement, Solid State Drive: passo 6, immagine 3 di 3
    • Use a Phillips #00 screwdriver to remove the single 2mm black screw from the SSD.
  7. One Education Infinity Solid State Drive Replacement: passo 7, immagine 1 di 3 One Education Infinity Solid State Drive Replacement: passo 7, immagine 2 di 3 One Education Infinity Solid State Drive Replacement: passo 7, immagine 3 di 3
    • Grab the SSD with your fingers and slide it slowly to the right and out of its port.
Conclusione
Cal Poly, Team S11-G4, Regan Fall 2019 Membro di Cal Poly, Team S11-G4, Regan Fall 2019
CPSU-REGAN-F19S11G4
3 Membri
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 404
