Salta al contenuto principale
OnHub Speaker Grille Replacement
Cosa ti serve
  1. OnHub Speaker Grille Replacement, Speaker Grille: passo 1, immagine 1 di 2 OnHub Speaker Grille Replacement, Speaker Grille: passo 1, immagine 2 di 2
    • Make sure the device is unplugged before proceeding with the disassembly.
    • While holding the base firmly using the palm of one hand, remove the cowl (cover) by turning the cowl counterclockwise until a snap is heard. Once disengaged, pull upwards.
  2. OnHub Speaker Grille Replacement: passo 2, immagine 1 di 1
    • Place the plastic opening tool under the speaker grille, and just above the light ring.
    • Move the plastic opening tool around the groove while applying upward force to pry loose the 4 clips holding the grille in place.
  3. OnHub Speaker Grille Replacement: passo 3, immagine 1 di 2 OnHub Speaker Grille Replacement: passo 3, immagine 2 di 2
    • Using a metal spudger, carefully remove the congestion-sensor antenna by undoing the two clips.
    • There is a delicate wire connection to the antenna that is easily broken if not careful.
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team 3-3, Sullivan Spring 2016 Membro di USF Tampa, Team 3-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G3
3 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 20
Tutti i Tempi: 314
