Salta al contenuto principale
Omaker M4 Port Cover Replacement
Cosa ti serve
  1. Omaker M4 Port Cover Replacement, Back Case: passo 1, immagine 1 di 1
    • Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
  2. Omaker M4 Port Cover Replacement: passo 2, immagine 1 di 2 Omaker M4 Port Cover Replacement: passo 2, immagine 2 di 2
    • Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device.
  3. Omaker M4 Port Cover Replacement: passo 3, immagine 1 di 2 Omaker M4 Port Cover Replacement: passo 3, immagine 2 di 2
    • Use a magnet to remove the screws after unscrewing them and place them aside.
  4. Omaker M4 Port Cover Replacement: passo 4, immagine 1 di 1
    • Carefully remove the back cover without breaking the battery wire.
  5. Omaker M4 Port Cover Replacement: passo 5, immagine 1 di 2 Omaker M4 Port Cover Replacement: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the end of the battery connection from the motherboard by holding the end of the wire and carefully pulling it out of the socket using tweezers.
    • The battery is still attached to the back cover.
  6. Omaker M4 Port Cover Replacement, Motherboard: passo 6, immagine 1 di 2 Omaker M4 Port Cover Replacement, Motherboard: passo 6, immagine 2 di 2
    • Remove the mic wire by carefully pulling the plug out of the socket.
  7. Omaker M4 Port Cover Replacement: passo 7, immagine 1 di 1
    • Remove the speaker wire by carefully pulling the plug out of the socket on the motherboard.
  8. Omaker M4 Port Cover Replacement: passo 8, immagine 1 di 2 Omaker M4 Port Cover Replacement: passo 8, immagine 2 di 2
    • Use Phillips PH00 screwdriver to remove the three screws holding the motherboard in place.
  9. Omaker M4 Port Cover Replacement: passo 9, immagine 1 di 2 Omaker M4 Port Cover Replacement: passo 9, immagine 2 di 2
    • Remove the screws using the screwdriver.
    • Since the screws that hold the motherboard in place are smaller, the screwdriver is able to pick them up.
  10. Omaker M4 Port Cover Replacement: passo 10, immagine 1 di 2 Omaker M4 Port Cover Replacement: passo 10, immagine 2 di 2
    • Carefully remove the motherboard with your hand by lifting it from the device.
  11. Omaker M4 Port Cover Replacement, Port Cover: passo 11, immagine 1 di 2 Omaker M4 Port Cover Replacement, Port Cover: passo 11, immagine 2 di 2
    • Separate the port cover from the device using your hands.
  12. Omaker M4 Port Cover Replacement: passo 12, immagine 1 di 1
    • Orient the device so the port cover is on your left.
  13. Omaker M4 Port Cover Replacement: passo 13, immagine 1 di 2 Omaker M4 Port Cover Replacement: passo 13, immagine 2 di 2
    Compra
    • Using Tweezers, pinch the larger part of the stem
  14. Omaker M4 Port Cover Replacement: passo 14, immagine 1 di 1
    • Use your left hand to pull while at the same time use the tweezers to compress the stem, carefully remove the port cover from the device.
Conclusione
Altre 2 persone hanno completato questa guida.
Obaida Matar
Membro da: 02/17/16
119 Reputazione
1 Guida realizzata
USF Tampa, Team 2-2, Sullivan Spring 2016 Membro di USF Tampa, Team 2-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G2
3 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 387
