Salta al contenuto principale
Olympus VR-350 Back Plate Replacement
Cosa ti serve
  1. Olympus VR-350 Back Plate Replacement, Front Plate: passo 1, immagine 1 di 2 Olympus VR-350 Back Plate Replacement, Front Plate: passo 1, immagine 2 di 2
    • Remove the two 4mm screws from each side of the camera with a Phillips PH000 screwdriver.
  2. Olympus VR-350 Back Plate Replacement: passo 2, immagine 1 di 1
    • Remove the four 4mm screws from the bottom of the camera with a Phillips PH000 screwdriver.
  3. Olympus VR-350 Back Plate Replacement: passo 3, immagine 1 di 3 Olympus VR-350 Back Plate Replacement: passo 3, immagine 2 di 3 Olympus VR-350 Back Plate Replacement: passo 3, immagine 3 di 3
    • Use the plastic opening tools and your fingers to pry the front plate from the camera.
    • You might need to open the battery cover to remove the front plate.
  4. Olympus VR-350 Back Plate Replacement, Back Plate: passo 4, immagine 1 di 2 Olympus VR-350 Back Plate Replacement, Back Plate: passo 4, immagine 2 di 2
    • Use your fingers to pry open the back cover.
    • When you remove the back of the camera, the button membrane might fall out. Don’t lose this sheet.
    • The LCD screen is connected to the body of the camera by an orange ribbon cable. Don’t pull this ribbon cable out.
Conclusione
Adri
Membro da: 02/23/15
456 Reputazione
3 Guide realizzate
USF Tampa, Team 1-3, Leahy Winter 2015 Membro di USF Tampa, Team 1-3, Leahy Winter 2015
USFT-LEAHY-W15S1G3
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 17
Tutti i Tempi: 730
