Salta al contenuto principale
Olympus Tough TG-1 Screen Replacement
Cosa ti serve
  1. Olympus Tough TG-1 Screen Replacement, Clip Side Repair: passo 1, immagine 1 di 2 Olympus Tough TG-1 Screen Replacement, Clip Side Repair: passo 1, immagine 2 di 2
    • Remove both 6 mm screws from the clip side of the camera.
    • After you have removed the two screws, remove both the clip and the plate behind the clip so that the inside of the camera is exposed.
    • If one of more of the clips appear to be broken, the back plate might need to be replaced.
  2. Olympus Tough TG-1 Screen Replacement, Top of Camera: passo 2, immagine 1 di 1
    • The top of the camera does not contain screws. You do not need to remove anything from the top of the camera.
  3. Olympus Tough TG-1 Screen Replacement, Plug Side: passo 3, immagine 1 di 3 Olympus Tough TG-1 Screen Replacement, Plug Side: passo 3, immagine 2 di 3 Olympus Tough TG-1 Screen Replacement, Plug Side: passo 3, immagine 3 di 3
    • Remove the two 5 mm screws on the side of the camera with the plug.
    • Open the compartment door and remove both 6 cm screws inside of the compartment door. This will allow you to remove the tan piece held by the screws.
  4. Olympus Tough TG-1 Screen Replacement, Bottom: passo 4, immagine 1 di 1
    • Turn the camera so that you are looking at the bottom of the camera.
    • Remove the two 4 mm screws from the bottom of the camera.
    • The screws are different. The rear screw is has an unthreaded shank to locate the outer shell while screwing into the inner frame.
  5. Olympus Tough TG-1 Screen Replacement, Front Panel: passo 5, immagine 1 di 3 Olympus Tough TG-1 Screen Replacement, Front Panel: passo 5, immagine 2 di 3 Olympus Tough TG-1 Screen Replacement, Front Panel: passo 5, immagine 3 di 3
    • Use the plastic opening tool to remove both components of the front panel. This includes the black part on the outside of the front panel and the main silver panel.
    • Once every screw and panel is removed, you can replace the backplate to make your camera weatherproof again.
  6. Olympus Tough TG-1 Screen Replacement, Opening the Internal Case: passo 6, immagine 1 di 3 Olympus Tough TG-1 Screen Replacement, Opening the Internal Case: passo 6, immagine 2 di 3 Olympus Tough TG-1 Screen Replacement, Opening the Internal Case: passo 6, immagine 3 di 3
    • Using the plastic opening tools, carefully open the case.
    • Do not tear the white circuit ribbon.
  7. Olympus Tough TG-1 Screen Replacement, Opening the Screen's Protective Cover: passo 7, immagine 1 di 3 Olympus Tough TG-1 Screen Replacement, Opening the Screen's Protective Cover: passo 7, immagine 2 di 3 Olympus Tough TG-1 Screen Replacement, Opening the Screen's Protective Cover: passo 7, immagine 3 di 3
    • Using the screwdriver, remove the ten 3mm anchor screws.
    • Using the plastic opening tool, open the protective cover so that the screen is exposed.
  8. Olympus Tough TG-1 Screen Replacement, Unclipping the Screen from the Circuit Ribbon: passo 8, immagine 1 di 1
    • Carefully unclip the screen from its circuit ribbon.
Conclusione
USF Tampa, Team 4-6, Brown Winter 2015 Membro di USF Tampa, Team 4-6, Brown Winter 2015
USFT-BROWN-W15S4G6
4 Membri
12 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 30
Ultimi 30 Giorni: 88
Tutti i Tempi: 3,150
