Salta al contenuto principale
Olympus Tough TG-1 Battery Replacement
  1. Olympus Tough TG-1 Battery Replacement, Battery Removal: passo 1, immagine 1 di 1
    • Release both latches on the battery compartment on the bottom of the camera to open the door.
  2. Olympus Tough TG-1 Battery Replacement: passo 2, immagine 1 di 1
    • After you have removed the latch, open the compartment door to remove the battery.
    • The batteries contain highly acidic contents. If the battery has leaked or ruptured while inside the compartment, there may be damage to the camera's circuitry. Carefully clean out any residue from the battery using latex gloves and tissues.
    • If the compartment door is loose, check the hinge or the locking pieces under the rubber pad. To do this, unscrew and remove the rubber and metal plate on the door.
Conclusione
USF Tampa, Team 4-6, Brown Winter 2015 Membro di USF Tampa, Team 4-6, Brown Winter 2015
USFT-BROWN-W15S4G6
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,021
