Salta al contenuto principale
Olympus TG-820 iHS Motherboard Replacement
Cosa ti serve
  1. Olympus TG-820 iHS Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Orient camera to look directly at battery compartment side as shown.
  2. Olympus TG-820 iHS Motherboard Replacement: passo 2, immagine 1 di 3 Olympus TG-820 iHS Motherboard Replacement: passo 2, immagine 2 di 3 Olympus TG-820 iHS Motherboard Replacement: passo 2, immagine 3 di 3
    • Locate the two latches on the battery compartment.
    • First, move the "lock" switch left to reveal red indicator.
    • Next, move the "cover latch" switch downward to reveal red indicator.
    • You have to move the switches in that order for the compartment to unlatch.
  3. Olympus TG-820 iHS Motherboard Replacement: passo 3, immagine 1 di 2 Olympus TG-820 iHS Motherboard Replacement: passo 3, immagine 2 di 2
    • Allow the battery compartment latch to completely open.
    • Insert battery with the writing face up.
    • The bigger slot is for the battery. The smaller slot is for the memory card.
    • Battery not shown.
  4. Olympus TG-820 iHS Motherboard Replacement, Back Case: passo 4, immagine 1 di 1
    • Orient the camera so you are looking at the bottom.
    • Remove the three 3.85mm Phillips #00 screws from the bottom of the camera.
  5. Olympus TG-820 iHS Motherboard Replacement: passo 5, immagine 1 di 1
    • Orient the camera so you are looking at the side plate.
    • Remove the two 3.15mm Phillips #00 screws from the side plate of the camera.
  6. Olympus TG-820 iHS Motherboard Replacement: passo 6, immagine 1 di 2 Olympus TG-820 iHS Motherboard Replacement: passo 6, immagine 2 di 2
    • Orient the camera so you are looking at the front plate.
    • Remove the two 3.8mm with the Phillips H1.5 from the front plate.
    • Remove the "Olympus" plate.
  7. Olympus TG-820 iHS Motherboard Replacement: passo 7, immagine 1 di 1
    • Remove face plate.
  8. Olympus TG-820 iHS Motherboard Replacement: passo 8, immagine 1 di 3 Olympus TG-820 iHS Motherboard Replacement: passo 8, immagine 2 di 3 Olympus TG-820 iHS Motherboard Replacement: passo 8, immagine 3 di 3
    • Locate three small black screws inside of the battery compartment.
    • Remove the 3.85mm Phillips #00 screw on the far left side.
    • Remove the two 5mm Phillips #00 screws on the right side
  9. Olympus TG-820 iHS Motherboard Replacement: passo 9, immagine 1 di 3 Olympus TG-820 iHS Motherboard Replacement: passo 9, immagine 2 di 3 Olympus TG-820 iHS Motherboard Replacement: passo 9, immagine 3 di 3
    • Orient the camera to be look at the top.
    • Remove the 5.4mm Phillips #00 screw on the top left side.
    • Remove the 7.4mm Phillips #00 screw next to the "ON/OFF" label.
    • Pry off top button plate with black nylon spudger.
  10. Olympus TG-820 iHS Motherboard Replacement: passo 10, immagine 1 di 2 Olympus TG-820 iHS Motherboard Replacement: passo 10, immagine 2 di 2
    • Rotate to bottom of camera and locate bottom latch.
    • Wedge black nylon spudger in between bottom latch and camera base to release LCD Screen from camera.
    • Push firmly apart.
    • Some buttons might fall out.
  11. Olympus TG-820 iHS Motherboard Replacement: passo 11, immagine 1 di 3 Olympus TG-820 iHS Motherboard Replacement: passo 11, immagine 2 di 3 Olympus TG-820 iHS Motherboard Replacement: passo 11, immagine 3 di 3
    • Orient the camera to the LCD screen side that is now wedged open.
    • Locate the white ribbon cable and pull out from motherboard.
    • Locate the brown ribbon cable and pull out from motherboard.
  12. Olympus TG-820 iHS Motherboard Replacement, Motherboard: passo 12, immagine 1 di 2 Olympus TG-820 iHS Motherboard Replacement, Motherboard: passo 12, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the four 3mm Phillips #000 screws.
    • Use tweezers to remove metal plate
    • There is now full access to the motherboard which you can replace components on by soldering.
Conclusione
Clemson, Team 7-2, Benson Spring 2016 Membro di Clemson, Team 7-2, Benson Spring 2016
CLEM-BENSON-S16S7G2
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 15
Tutti i Tempi: 820
