Salta al contenuto principale
Olympus TG-820 iHS Locking Mechanism Replacement
Cosa ti serve
  1. Olympus TG-820 iHS Locking Mechanism Replacement, Battery: passo 1, immagine 1 di 1
    • Orient camera to look directly at battery compartment side as shown.
  2. Olympus TG-820 iHS Locking Mechanism Replacement: passo 2, immagine 1 di 3 Olympus TG-820 iHS Locking Mechanism Replacement: passo 2, immagine 2 di 3 Olympus TG-820 iHS Locking Mechanism Replacement: passo 2, immagine 3 di 3
    • Locate the two latches on the battery compartment.
    • First, move the "lock" switch left to reveal red indicator.
    • Next, move the "cover latch" switch downward to reveal red indicator.
    • You have to move the switches in that order for the compartment to unlatch.
  3. Olympus TG-820 iHS Locking Mechanism Replacement: passo 3, immagine 1 di 2 Olympus TG-820 iHS Locking Mechanism Replacement: passo 3, immagine 2 di 2
    • Allow the battery compartment latch to completely open.
    • Insert battery with the writing face up.
    • The bigger slot is for the battery. The smaller slot is for the memory card.
    • Battery not shown.
  4. Olympus TG-820 iHS Locking Mechanism Replacement, Locking Mechanism: passo 4, immagine 1 di 3 Olympus TG-820 iHS Locking Mechanism Replacement, Locking Mechanism: passo 4, immagine 2 di 3 Olympus TG-820 iHS Locking Mechanism Replacement, Locking Mechanism: passo 4, immagine 3 di 3
    • Locate and remove the 4.7mm Phillips #000 screw on the back side of the battery compartment locking mechanism.
    • Locate and remove the 4.7mm Phillips #000 screw on the front side of the battery compartment locking mechanism.
  5. Olympus TG-820 iHS Locking Mechanism Replacement: passo 5, immagine 1 di 1
    • Locate the two screws on the side of the battery compartment.
    • Remove the two 4.85mm Phillips #000 screws.
  6. Olympus TG-820 iHS Locking Mechanism Replacement: passo 6, immagine 1 di 2 Olympus TG-820 iHS Locking Mechanism Replacement: passo 6, immagine 2 di 2
    • Once all 4 screws are out, the back panel of the battery compartment will come off.
    • The entire battery compartment cover will also detach from the camera.
Conclusione
Clemson, Team 7-2, Benson Spring 2016 Membro di Clemson, Team 7-2, Benson Spring 2016
CLEM-BENSON-S16S7G2
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 433
