Salta al contenuto principale
Olympus Stylus Tough-8010 Side Panel Replacement
Cosa ti serve
  1. Olympus Stylus Tough-8010 Side Panel Replacement, Side Panel: passo 1, immagine 1 di 3 Olympus Stylus Tough-8010 Side Panel Replacement, Side Panel: passo 1, immagine 2 di 3 Olympus Stylus Tough-8010 Side Panel Replacement, Side Panel: passo 1, immagine 3 di 3
    • Remove the three screws (3.2mm) from the front panel using a T-6 screwdriver.
    • Take off the smaller front panel cover.
    • Carefully remove the larger front cover.
  2. Olympus Stylus Tough-8010 Side Panel Replacement: passo 2, immagine 1 di 3 Olympus Stylus Tough-8010 Side Panel Replacement: passo 2, immagine 2 di 3 Olympus Stylus Tough-8010 Side Panel Replacement: passo 2, immagine 3 di 3
    • Remove the top two screws (4.1mm) using a #000 Phillips head screwdriver.
    • Remove the two screws (7.9mm) near the control pad. Set metal connector aside.
    • Remove the side panel casing.
  3. Olympus Stylus Tough-8010 Side Panel Replacement: passo 3, immagine 1 di 3 Olympus Stylus Tough-8010 Side Panel Replacement: passo 3, immagine 2 di 3 Olympus Stylus Tough-8010 Side Panel Replacement: passo 3, immagine 3 di 3
    • Using a #000 Philips head screwdriver, remove the two screws (4.1mm) on the right side of the camera.
    • Remove the two screws (4.1mm) from the bottom of the camera.
    • Remove the single screw (3.2mm) from the front of the camera.
  4. Olympus Stylus Tough-8010 Side Panel Replacement: passo 4, immagine 1 di 2 Olympus Stylus Tough-8010 Side Panel Replacement: passo 4, immagine 2 di 2
    • Carefully remove the front panel piece.
    • Remove the screw (7.9mm) from the bottom left hand corner using a #000 Phillips head screwdriver.
  5. Olympus Stylus Tough-8010 Side Panel Replacement: passo 5, immagine 1 di 3 Olympus Stylus Tough-8010 Side Panel Replacement: passo 5, immagine 2 di 3 Olympus Stylus Tough-8010 Side Panel Replacement: passo 5, immagine 3 di 3
    • Slightly bend the metal that is covering the side panel axle.
    • Using a paperclip, completely push out the metal bar that holds the side panel to the camera.
    • Remove the side panel door.
Conclusione
James G Payne
Membro da: 03/23/15
225 Reputazione
2 Guide realizzate
Baylor, Team 7-15, Williams Spring 2015 Membro di Baylor, Team 7-15, Williams Spring 2015
BU-WILLIAMS-S15S7G15
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 12
Tutti i Tempi: 350
