Salta al contenuto principale
Olympus Stylus Tough-8010 Battery Replacement
  1. Olympus Stylus Tough-8010 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Open the side panel that allows access to the battery by turning the circular lock mechanism counterclockwise.
    • Slide the locking mechanism up. You should see red when the camera is unlocked.
  2. Olympus Stylus Tough-8010 Battery Replacement: passo 2, immagine 1 di 1
    • Open the side panel and check for any obstructions in the battery slot.
    • Insert the battery in the correct orientation in the battery slot.
Conclusione
James G Payne
Membro da: 03/23/15
225 Reputazione
2 Guide realizzate
Baylor, Team 7-15, Williams Spring 2015 Membro di Baylor, Team 7-15, Williams Spring 2015
BU-WILLIAMS-S15S7G15
3 Membri
12 Guide realizzate
Un commento
i can’t open the battery door
Kayla Chatman - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,021
